differences in TPI between GM and Pontiac ?
I'm considering buying a TPI setup from a 86 Pontiac transam.
Can this setup be used on a Chevrolet engine ? What are the differences (ECM,...)
Is calibration much different ?
Yves
Yves
Car: 2004 BMW 330Cic
Engine: 3.0
Transmission: 6 speed
There are no differences. Trans Ams came exclusively with Chevy engines since 1982. All Firebirds share their drivetrain components with Camaros, the only diffence being the air intake/filter system due to different hood lines.
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
the unit itself is the same.
the wiring harnesses between camaros and firebirds are diffrent in some cases.
whats the exact year and model of each car?
Car: 91 Camaro Vert
Re: wiring
Originally posted by Yves
I buy the intire wiring from the car. So I thought I should have no problem, but wanted to make sure
The intention is to fuel inject my 79 vette and try reprogram it.
Yves
Yves
oh, in that case, yes you can make it work.
thefirebirdm@n
South Central Region
Sep 14, 2015 01:45 PM
kah992
Aug 19, 2015 02:55 PM
Sanjay
Aug 12, 2015 03:41 PM
