Highway mode... built in?
Old Nov 12, 2003 | 07:28 PM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Hmmm... I noticed that theres really no way to turn off the highway mode in my ecm (8063) with my present tuning software. It just sorta comes with the territory I can cut the spark but the ecm will still pull the fuel untill the stock 02 reads almost nill. Its kind of annoying, all i have controll over is the spark, not the AFRs or the fueling. My 02 voltages go down to around .003-.004. Is HW mode supposed to run the engine that lean? It just seems like theres nothing but air going through my exaust.
Old Nov 12, 2003 | 10:46 PM
Car: 88 Camaro SC
Engine: SFI'd 350
how does teh ecm calculate the necesary fueling in HW mode? I assume it just goes right off the main %VE table?
Old Nov 13, 2003 | 07:05 AM
JPrevost's Avatar
Car: 91 Red Sled
Highway mode is just like PE mode only it tends to lean out. There are tables that change the desired AFR while in highway mode just as PE mode.
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2442507003
I might go through and see if I can't find you your highway tables.
Old Nov 13, 2003 | 07:18 AM
JPrevost's Avatar
Car: 91 Red Sled
I found the table for your highway mode AFR vs vacuum. It starts at location 390, you'll find 96 96 A6 A6 A0 9B 96 90 90. Download the demo of the tdf editor from TC and add that table to your tdf file. It's amazing how similar your ecm is to the 8746. I just had to search for the common afr table in my ecm and bingo, it's the same thing in yours, just in a different location.
You have GOT to get Hex Workshop. Look at how long it took me to figure that out, .
Old Nov 13, 2003 | 12:01 PM
Car: 88 Camaro SC
Engine: SFI'd 350
Jon, what are the units of the table? I assume the X-axis has the units of AFR but what about the Y-axis? Is it just values of map?
RedLeader289
May 28, 2019 01:47 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
6998poncho
Sep 25, 2015 02:56 PM
