Injectors Staying Open - gallons of fuel.
Old Nov 23, 2003 | 01:34 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Transmission: 700 R4
Axle/Gears: 370 BW
Does anyone know of something that could force all the injectors to stay open? The injectors themselves seem in good shape. Ohms are between 13 to 14 on all eight. I've tested them on the fuel rail and out of the intake and none leaked. It appears that all eight are doing the same thing and everything was fine yesterday morning (until I had installed a new prom with a messed up BIN file) Stock chip has been reinstalled since then.
When I turn the engine over with the spark plugs out, I get lots of gas pouring out of the plug holes. I had 1/2 to a full gallon that had collected in the crankcase. Since then I flushed and refilled with fresh oil.
I felt that the injectors could have been binding and raised the fuel rail to release any possible pressure on them. I crank the car 5 - 10 revolutions get out and fuel pressure is close to zero, gas all over the headers from the plug holes, I disconnect the battery and after a few seconds fuel pressure raises to 15 - 20 and then very, very slowly starts to drop.
Could something be wrong with the ECM or a short in the wiring harness? It seems like the injectors are wide open and spraying constantly while cranking.
Old Nov 23, 2003 | 02:48 PM
305sbc's Avatar
Car: 1986 Irocz
Axle/Gears: 3.25:1
If the injector driver wire is shorted to ground that would explain it. The injectors get 12v all the time on one wire when the key is forward. The ECM pulses the ground side, so if you short to ground then they stay on.
Don't rule out a short inside the ECM. Have you tried another ECM?
Old Nov 23, 2003 | 04:29 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
305sbc, thank you so much for the reply. Right before checking your post, I had found one of the injector wires (purple and black) was grounding into the block (from a pinched wire), could that make both banks stay open or just one bank?
Old Nov 23, 2003 | 07:23 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
All.
While there are two wires that the ecm grounds to fire the injectors, they are tied together in the ecm. So short either to ground and they all stay on.
Old Nov 23, 2003 | 11:15 PM
jo88gta's Avatar
Car: 88 GTA
Engine: 355 TPI
Axle/Gears: 370 BW
Grumpy, Thanks!
That save me a lot of searching.
Ghettobird52
Jul 5, 2024 11:18 PM
Street Lethal
Apr 30, 2019 12:14 PM
Bubbajones_ya
Aug 28, 2015 02:17 AM
Jae992
Aug 27, 2015 09:07 AM
ezobens
Aug 19, 2015 10:29 PM
