effects of length of MAP sensor line.
Old Nov 14, 2003 | 09:17 AM
MrDude_1's Avatar
Car: 91 Camaro Vert
Engine: 02 LS1, HX40
Transmission: 2002 LS1 M6
grumpy said somthing that made me curious..
Originally posted by Grumpy
One of the MAP concerns is how it's tied to the engine.
The size, type, and lenght of line all matters.
3' of 1/4" line is alot different then bolting the sensor to the manifold, like they did on some of the v 6's.
how does changing the line to a map sensor effect everything with a SD system? whats the overall effect? could changing the line length effect the "pump shot" making the engine bog with large throttle changes? how sensitive is the setup?
Old Nov 14, 2003 | 10:33 AM
Grim Reaper's Avatar
Car: Death Mobile
Engine: 666 c.i.
The line will absorb some of the "energy" of the engine vacuum the longer the line and softer the material. Thus is will be slower to react and may affect the actual reading if the length is long and made with soft rubber.
Think of it as "sucking through a straw".
Old Nov 14, 2003 | 12:08 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: effects of length of MAP sensor line.
The MAP sensor and it's signal are critical.
The line CAN act as a filter. ie absorbing the intake manifold's most drastic of pulsations.
There are two ways of handing the extremes, one is with mechanical filtering, the line, and the other in the code.
When the code is running, it samples the MAP from time to time, it's not constantly being used. The code runs in a series of loops, it does something, say TPS AE, and then will do EGR, then Timing, then TCC, maybe MAP lookup, then on and on thur these sections of code.
The MAP signal needs some conditioning to avoid the ecm seeing all the puslations as just chatter, and making huge swings in adjustments.
Some cars, trucks, are extremely sensitive to little changes in the MAP line, while others really don't seem too effected by it.
Yes, it will effect the MAP AE, and how fast the ecm can transverse reading the VE table.
Pep Boys and Advance used to carry the same type small semi hard plastic lines, like GM uses.
Old Nov 14, 2003 | 03:32 PM
Denis.V's Avatar
Car: 1986 Pontiac Firebird Trans Am
Engine: 305 Tuned Port Injection
Transmission: The famous 700R4
Axle/Gears: No idea
Then, if I replace a 2mm. wide vacuum line for a new wide 3mm. vacuum line - in a 600 mm. longitude line - I must cut the line to 400 mm., Since:
- Old vacuum volume in MAP line = 2mm. x 600mm. = 1200mm3.
- New vacuum volume = 3mm. x 400mm. = 1200mm3.
(Formulas aren't right but it's the idea).
This is?..
Denis V.
Old Nov 14, 2003 | 03:57 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
This is?..
Volume change primarily effects the timing, or amount of delay for the MAP to react.
The wall stiffness, primarily effects the dampening of the signal.
They do act in concert.
Old Nov 19, 2003 | 10:16 PM
funstick's Avatar
for giggle recently i ran a 15ft 1/4 vac line on a car and stopped the MAP AE and focusosed directly on the TPS AE and using it to my full advanatge., after a bit of tweaking i found the idle to be easier to stabilize and the AE problems that had been noted in the past were fiarly minmal. just throwing my 2cents in there,.
Old Nov 19, 2003 | 11:03 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Just to further this a bit, I'm figuring that too small a vac line will delay the signal because of impedance to flow, and too large a line could also delay it due to the amount of time for the larger amount of air to move. Am I thinking ok on this? Is too big, AND too small gonna slow down (delay) the signal? Is there any reason someone may want to do something like this? I would think you would want the fastest, most accurate signal you can get.
Just doin some thinking out loud here.
I have noticed that pretty much all of the newer GM's have the MAP sensor mounted directly IN the intake (SBC Vortec, 3800 with the plastic plenum), or at least just connected with a rubber "TEE" (3100 "M")... I gather that this setup would have the quickest response, and no dampning whatsoever.
Old Nov 20, 2003 | 08:57 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
There is no real flow.
More like only a slight shifting of air as it moves back and forth.
Introduce a pin hole, near the sensor and then you have actual flow.
Old Nov 20, 2003 | 09:31 AM
va454ss's Avatar
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
So, with a slightly lumpy cam that pulls less vac than stock at idle, would you want to use a longer, softer hose to the MAP to lessen the pulsations?
Old Nov 20, 2003 | 01:06 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You first want to hook it up with the hard plastic like GM uses. If you're not happy with the results, then you can use the tubing as an attempt to help things. There's lots of variables, on making a sweeping statement may or may not be true for all applications.
The softer hose would dampen the pulsations. Minor, nit.
Old Nov 20, 2003 | 01:26 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
this is really the question i wanted to get to..
if i used a softer hose, and moved the map to the far part of the cowl, and ran a nice long line, would it help even out everything?
Old Nov 20, 2003 | 01:33 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
You can quite easily over dampen the signal.
Old Nov 20, 2003 | 02:01 PM
MrDude_1's Avatar
Car: 91 Camaro Vert
how would i be able to tell if im overdampening it or not?
i have a TBI computer, so the refresh rate is REALLY slow to see...
id just want to dampen the pulses out for a smoother idle...
is my only option to do trial and error with diffrent lengths and hose?
Old Nov 20, 2003 | 02:03 PM
funstick's Avatar
yep
Old Nov 20, 2003 | 03:56 PM
Car: Death Mobile
Engine: 666 c.i.
Yes, the display rate is quiet slow and limited in information. But the ECM clock speed is faster than the display. That is just the communication speed with the ALDL port.
I woudl say that you would "hear it" much sooner. Sometimes, these "scan tools" make us forget our other senses that "tuners and mechanics" used in the good old days.
No scan tools, no wide bands, no EGTs...just plugs, a stopwatch and a good nose and ear.
Old Nov 20, 2003 | 05:49 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Along with the ever important 'glutinous maximus' instrument.
RBob.
Old Nov 20, 2003 | 07:30 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
When you go too far it will be apparent.
Refresh rate has little to do with it.
There is no guarantee this will improve your idle.
Yes, you have to use all the tools and techniques available to get the best possible results, there are no silver bullets.
Old Nov 20, 2003 | 10:38 PM
89 Iroc Z's Avatar
Car: 1989 Iroc-Z
Engine: 350, ZZ4 equivalent
Transmission: Pro-Built Road Race 700R4
Axle/Gears: 3.23 Dana 44
So is hard plastic line bad?, like the kind that you get with aftermarket gauges? Because that’s what I am using. It is a lot smaller opening then the stock line used. That may explain my stumbling / stalling problem at idle-low rpm’s.
Old Nov 20, 2003 | 11:08 PM
steve8586iroc's Avatar
I think something was missed when it comes to lumpy idles caused by longer duration higher lift cams. No length of vacuum line, short or long, will make up for low vacuum at idle. This can only be taken care of by taking fuel and timing out by reprogramming the chip to account for the changes. Now once you are off idle, either crusing or accellerating, the map would come into play as far as having a greater roll in overall opperation of the engine.
Steve
Old Nov 21, 2003 | 08:00 AM
Denis.V's Avatar
Axle/Gears: No idea
I can see a wrong idea about the soft vacuum hoses.
I used light blue silicone soft vacuum hoses (very nice and beautiful in the catalog's pictures), but the only that I got was COLLAPSED vacuum lines when the engine was hot = 0 (zero) vacuum to MAP, bad idle, bad power, waste of time , waste of money and GRRRR! with this job (I went back with the original vacuum hoses).
Since You can't controls the engine compartment temperature, you can't controls the more or less "soft" vacuum hose.
For me, the only way for MAP signal control is via EPROM + a short hard vacuum hose (It's only my opinion).
Old Nov 21, 2003 | 09:38 AM
Car: Death Mobile
Engine: 666 c.i.
That would be my preferene also.
As I recall, this was Bruce's original cavaet when the topic originally began in the other post. This post was more of a discussion on the possible effects of what happens when you use a longer and/or softer piece of hose.
Your experience with that "pretty blue hose" is a good point on what may also happen when things get heated up under the hood should you attempt to use a "mechanical" method to cure an eprom related problem (due to low vacuum). You may encounter further problems (if you don't notice that pretty blue hose collapses when hot).
Old Nov 21, 2003 | 05:41 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Nope, tis a different topic. This thread is about effects of lenght of MAP sensor line. It's something the non code guru can do to aid in tuning.
Using a rigid line and tuning the filtering rate in the chip is the best answer, but not always can we avail ourselves to the best answer.
Old Nov 21, 2003 | 05:47 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I don't see why it wouldn't work.
Stalling isn't what I'd expect to see as a problem from MAP line size.
Off idle and transistional problems are what I've seen most often as problems.
Old Nov 21, 2003 | 09:42 PM
I guess I should have directed my reply to va454ss and Mr. Dude. I still don't think the length of hose would have any affect on idle quality.
And as I should have said in my first post that off idle to wot, the length of hose my make a difference in overall engine operation.
Steve
Old Nov 23, 2003 | 10:33 AM
hectorsn's Avatar
Car: 78 Regal
Engine: 82 FBod LG4 305, 730 ECM
Transmission: M20
Axle/Gears: 4.10
You also said that to make it idle better you should take out timing and fuel. Now it's just my method of tuning lopy cams but I have found that adding timing and fuel will even out the idle not the opposite. But again, no one is trying to add vacuum by using different length and hard lines. What is trying to be accomplished is reducing the amount of erratic map readings that you get from lopy cams. It's the reversion in the intake that causes the fluctuations and you are right, no amount of vacuum line can get rid of it but maybe you can dull it enough so the sensor doesn't pick it up as much.
Old Nov 23, 2003 | 09:21 PM
I need to be carefull when I make a blanket statement as I did in my first post. I can see where you might want to add timing and fuel to a carburated setup, but I was under the impression that the computer added fuel when a low map signal was incountered. Now I know the tps and rpm play a role in all this as to what the ecm will give the engine as far as timing and fuel. I have heard so many times that when someone swaps in a cam with a slightly lumpy to very lumpy idle, before tuning, that the engine runs rich. So if I'm not totally screwed up that is what I have bassed my assumption on. I hope I havent left everyone scratching their head.
Steve
Old Nov 24, 2003 | 10:34 AM
GTA91's Avatar
Car: '91 GTA
Engine: 402ci LS2
Transmission: faceplated T56
Axle/Gears: 9" w/ 4.11's
Maybe thats some of my problems with my hotcam and SD with my relocated MAP.
gta892000
Aug 11, 2019 11:16 AM
customblackbird
Oct 1, 2015 04:30 PM
billybob6110
Sep 23, 2015 01:30 PM
sreZ28
Carburetors
24
Sep 21, 2015 04:54 PM
FormulasOnly
Sep 10, 2015 09:07 PM
