Romulator and USB 2 Serial (COM) Port adaptors
Old Dec 8, 2003 | 05:19 PM
xtronics's Avatar
From reading here it sounds like there may be some USB-2-Serial adapters out there that don't work. I'm guessing that some are due to the driver problems (that are supposed to now be fixed) in WinXP.
<p>
You should expect that the software supplied with a USB2Serial adapter will register the COM port with the OS (look in the device manager of your OS). If it won't – it isn't going to work.
<p>
Hope some of you can help the next guy - I would like to make a list - if you have a USB2Serial adapter - tell us 5 things
<br>
Does it work?
<br>
Manufacturer
<br>
Model
<br>
driver version
<br>
and what Operating system you have.
<p>
Email your answer to information@xtronics.com <b>AND</b> post it here.
Old Dec 8, 2003 | 06:07 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
Re: Romulator and USB 2 Serial (COM) Port adaptors
<p>
<p>
<br>
Does it work?
<br>
Manufacturer
<br>
Model
<br>
driver version
<br>
<p>
Ok I'll go first.
Here is what I bought.
It was one off ebay.
Does it work- no, it loads up fine but does not set a com port number. It loads as a HID and a virtual port.
MFR- China
Model- ? cypress
Driver- cypress virtual port, cypress semiconductor 9-17-2002
driver file details- WDMMDMLD.VXD, microsoft 4.10.2224
HID--com device, hidcom.sys, cypress semiconductor 0,0,0,15
OS- Win 98
also loaded it in XP which it did not use a driver from the supplied disk.
Old Dec 8, 2003 | 06:55 PM
BOWTYE8's Avatar
I'll Go second.
I am running radio shack usb to serial in a tosh laptop.
Its works great with romulator(both cats tuner and tunerpro RT)
Yes when the cable is plugged into the USB it will show under device manager.
Running under WinXP
Drivier verson is win2k (floppy came with cable)
I use this cable also with some other hobbies(programmers, and the LM1 wibeband O2)
fyif-Just plugging in the cable should show a display under device manager.
I have had zero luck with ALDL monitoring though. Datamaster,moates,tunerpro RT ALDL.....I know usb cable is good so not sure whats up. I can link with diacom and its cable. I purchased a fully assmbled OBD1 AKM cable. I have read every post on this on TGO.
I have not tried booting to win98 yet.
Sorry off topic. But I mention this for those buying the cable for ALDL purposes and having zero luck. I am there in that case also.
Dennis
Old Dec 8, 2003 | 07:43 PM
YenkoZ28's Avatar
Car: 1991 Z28
Engine: 305 TPI under 14 psi
Transmission: aftermarket T56
Axle/Gears: Moser 12 bolt 3.08 gears
I bought a socket communications pcima to serial card and it works great with datamaster and the romulator. Here is the link to the product http://www.socketcom.com/product/SL0707-078.asp it does cost more than a usb to serial setup though.
Old Dec 8, 2003 | 08:59 PM
Bill usn-1's Avatar
Car: IH Scout
Engine: 345 V8 TBI
Transmission: 727
All of my stuff runs on the pcmcia card also. But a lot of guys here are having trouble with the usb to serial cables..
That's what we are trying to figure out.
Thanks,
Old Dec 8, 2003 | 10:43 PM
Swapmaster's Avatar
Datamaster for sure and probably the other scan programs will not work with a USB/Serial adapter. They must be on a real Serial port. Cats programs will run on either. I have an old IBM Thinkpad running Datamaster on the only serial port it has and a Romulator running on the Radioshack USB/Serial adapter. The setup works perfect, never had a glitch from day one.
Falcon50
Aug 22, 2020 03:26 PM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
sammy52401
Nov 11, 2015 07:20 PM
Reid Fleming
Oct 10, 2015 09:56 PM
bplessy
Sep 30, 2015 12:14 PM
