Almost ready for fire up!
Old Dec 30, 2003 | 11:04 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Well, with the exception of the ignition, the EFI is wired in the Jeep and ready to roll. I am working with another TGO member to fix the ignition wiring problem and we should have it ready in a day or so.
When I initially fire the engine off, I know I need to set the mechanical idle, TPS, and timing. What else should I do when I finally have it running? Should I get a datalog of what it is doing at idle and go from there? I have modified the ANLU bin already with a target idle of 750 rpm and I have diasbled EGR and made sure VATS is disabled. I maxed out the TCC stuff to 255. I don't know if that will make a difference or not. I also zeroed out the coolant spark tables, but I can copy them back in if need be.
TIA
Old Dec 31, 2003 | 07:41 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
What assembly lube did you use?.
Does it contain a high zinc, phosphor, level?.
If so, I'd set the chip to stay in open loop and remove the O2 sensor for the break-in and maybe the first 100 miles until ehen every you change the oil.
Then pull a few degrees timing out everywhere but idle, and add a little fuel everywhere but idle.
You don't even want to risk a chance of detonating the motor during break in, IMO.
Assembly lubes, and sealants, can poison an O2 in just seconds, thou they can take a couple hundred miles to completely die. IMO, better just better to stuff a Ford 18mm spark plug in the bung for break in.
RS Reaper
Oct 17, 2018 07:52 PM
meeklay812
Oct 1, 2015 03:46 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
indygene
Sep 26, 2015 11:21 AM
