PPII Access Violation with 95
Old Jan 27, 2004 | 07:56 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Does anyone know how to cure this problem? When I open PPII it gives me the following message "Access violation at 00 45 CC 23 in module Win_PP2.exe Read at Address 00 AD 00 00." This is a basic window 95 desktop. Dell GX1 233 MHZ. When I click okay it allows me to blank check my chip but gives me the same message when I try to load bin file to burn. I tried to run this on my XP laptop. Any ideas would be appreciated. Thanks, BranZ
Old Jan 28, 2004 | 12:40 AM
dimented24x7's Avatar
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
AFAIK that means that, for whatever reason, the software cant load tehfile requested. Either its not there, corrupt, or some other problem prevents it from being loaded. Try a different file in another location and see if it can read another .bin .
Old Jan 28, 2004 | 08:26 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
the application is trying to read a block of memory thats locked or it otherwise doesn't have access to.
Maybe you should try Windows 3.1 (sarcasm). Be sure you have the latest version fo the software for starters. The next avenue is to contact Xtronics.
Old Feb 5, 2004 | 12:36 PM
BranZ's Avatar
Car: 1991 Z28
Engine: 5.7
Transmission: A4
Upgraded to 1.96
I emailed xtronics and they let me have the latest software. I installed it and it worked like a champ. It has taken me forever to get chip burning. I appreciate your help on this problem guys. BranZ
Old Feb 5, 2004 | 10:12 PM
walkerscott's Avatar
I had the same problem on a Windows ME & 2K OS using the latest version 1.96. Curious was the chip in the PPII socket when you opened the program?
blackz281le
Jan 11, 2016 07:51 AM
shanelique22
Sep 24, 2015 06:30 PM
CatmanFS
Sep 19, 2015 09:00 AM
