Need some help with some Scan Data
Old Mar 10, 2004 | 07:54 PM
ERICCAMARO's Avatar
Car: 92 camaro Rs
Engine: 305 tpi
Transmission: t-5 WC
How does this look?? is it right? I think the 02mv look low right? what does it have to be to go into closed loop? Blm's look high too right/? what do u think is the cause of this?
I hooked my car up to my computer and used moates software and a customefis cable and got these #s do they look good or is something outa whack? This is from my 92 camaro RS 305 TPI with manuel tranny
these were taken at idle
eng spd-775
Map signal- 1.35
Throttle pos. volts- .53
manifold temp- 142
coolant temp- 189
spark advance would jump from 12-14-17
Knock- 1
Map pres. value- 34.49
Iac steps-40
02 mV- 433
blm cell-4
blm- 140
int value- 128
fine fuel - 128
injector pulse width- 1.79
a/f ratio- 14.26
idle target- 775
battery volts- 13.5
any help will be appreciated.
Falcon50
Aug 22, 2020 03:26 PM
1992Z28!
Nov 19, 2015 07:33 AM
bjpotter
Oct 4, 2015 07:48 PM
MitcherNeaf
Sep 24, 2015 09:23 PM
RGB2015
Sep 20, 2015 09:26 PM
