Changing timing via chip
Subscribe
Mar 18, 2004 | 08:54 PM
I have an Lt1 cam in my 305 and I set the base timing to 6 deg. after researching a little I have found that people are running upwards of 10 deg. I might be thinking a little carazy but instead of getting out the tools could I just sort of lie to the chip basically telling it the base timing is at -4 deg? would this basically do the same thing or am I hitting the crack pipe?
Reply 0
Mar 19, 2004 | 01:33 AM
Crack smoker
If your doing your own chips, putting the correct value in the chip makes the ALDL read correctly among other things.
Changing the base timing w/o changing the code is just making a global change to the timing. The code adds or subtracts timing the same amount regardless of base setting.
It's a quick method to see if you need more or less. Just a band aid tuning method. If you can burn chips, keep all the numbers straight. Saves on confusion.
Some peoples cars won't even run with 6 degs static.
How are you going to lie to the chip w/o tools?
Reply 0
Mar 19, 2004 | 06:08 AM
Re: Changing timing via chip
Quote:
At 10 on a hot day you might have the engine crank too slow to start.
6-8d, initial, and adjust the tune with the chip.
Once you change cams, you'll need to change items other then just timing if you want to get the tune correct.
Reply 0
Mar 19, 2004 | 07:13 AM
I knew things would have to be tuned but I was just curious if the base timing was changed in the chip if it basically change the whole timing curve on a global scale. Thanks for your input guys.
Reply 0
Subscribe
