A/D vs Temp values...8746 $61
Old Mar 19, 2004 | 01:39 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Okay, you guys are probably gonna think I am an idiot for trying this, but it works so far. I just need to get the right values in the constants. I already searched and can't find anything to help.
I live in a state that doesn't really have emissions controls, so I don't run an EGR valve. My Edelbrock manifold doesn't even have provisions for one. SO...when I wired the TBI up in the Jeep, I left enough wire coming off of pin A4 for me to be able to tie back into it again to control another relay...for my electric fan. Basically, it fools the ECM into thinking that the EGR solenoid is there when it is actually a fan relay.
I am trying to tweak the EGR On/Off (Temp) constants to cause the ECM to power up the fan at 190F and turn it off at about 177F. I have the table that comes with the A090 definition, but it ranges from -40F (253 a/d counts) to something like 150F (25 a/d counts). Is there an expanded version of this table that includes the approximate a/d counts for the temperature range I am targeting? If not, is there a conversion equation?
TIA!!!
Old Mar 19, 2004 | 02:41 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
That table should be degrees C not F.
RBob.
Code:
;* Table 1 --- Coolant Temperature, 1k pu
;* 	 A/D 	degrees		A/D
;* 	counts     C		Inv
;* 	255	    -40		  0
;* 	251	    -30		  4
;* 	250	    -25		  5
;* 	247	    -20		  8
;* 	245	    -15		 10
;* 	241	    -10		 14
;* 	237	    - 5		 18
;* 	231	      0		 24
;* 	225	      5		 30
;* 	218	     10		 37
;* 	209	     15		 46
;* 	199	     20		 56
;* 	189	     25		 66
;* 	177	     30		 78
;* 	165	     35		 90
;* 	152	     40		103
;* 	139	     45		116
;* 	126	     50		129
;* 	114	     55		141
;* 	102	     60		153
;* 	92	     65		163
;* 	81	     70		174
;* 	72	     75		183
;* 	64	     80		191
;* 	56	     85		199
;* 	50	     90		205
;* 	44	     95		211
;* 	39	    100		216
;* 	34	    105		221
;* 	30	    110		225
;* 	26	    115		229
;* 	23	    120		232
;* 	21	    125		234
;* 	18	    130		237
;* 	16	    135		239
;* 	14	    140		241
;* 	13	    145		242
;* 	12	    150		243
;* 	0	    200		255
Old Mar 19, 2004 | 02:58 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Got it...you are right about the deg C thing. I just saw that when you said it. I really am an idiot.
Is there a way to take the speed controls out of the EGR control loop by changing constants or is it more involved than that? The temperature control seems to work fine and the ECM is actually running the fan for me, but it doesn't want to run it when I have the engine running. Did I do something wrong or is this not gonna work like I want it to?
Bubbajones_ya
Jul 6, 2024 08:32 PM
sheachopper
Jul 31, 2019 11:27 AM
ULTM8Z
Oct 2, 2015 01:25 PM
SS-EXPRESS
Sep 28, 2015 09:14 AM
ironbmt
Sep 27, 2015 06:00 AM
