WinALDL help....!!!!
Old Mar 25, 2004 | 08:38 PM
Cooter77's Avatar
Car: 89 IROC-Z / 11 2500 Sierra
Engine: 5.7 & Duramax
I am having trouble getting the data to show up.. If you look at my pic this is all I get while car is in motion. When I first start car every once and a while the EGR, RPM and TPS will get a signal but then go away. I made a com cable that looks like the interface2.gif file. I did not use R4 becuse I'm running TPI.
Also have tried the TunerPro RT and I get connections and some info but, no real data.
I have a 1227165 ECU.
'89 IROC-Z 5.7
I've searched for hours and hours on these forums and cannot find similiar problems.
I have just rebuilt the motor in my cam and I'm in the begining stages of prom tuning. I know it needs it bad. Now when I go WOT it spark knocks and pisses carbon all over behind me.. hehe.
Likes to leave black spots.
Any help on this matter or direction where to go would be a great help. I might even have a 6-pack delivered to yer doorstep..!!
Old Mar 26, 2004 | 11:21 AM
brennanw's Avatar
Car: 1956 Willys
Engine: 383 TBI
Transmission: SM465
I had the same problem a while back. You need to increase the baud rate by using the "configuration" button.
Old Mar 26, 2004 | 06:50 PM
Cooter77's Avatar
When do I increase baud rate.
Before I start car.... don't matter when..??
I have played w/ the baud and it didn't make a difference.
I will try again tomarro.
Old Mar 27, 2004 | 12:38 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
'89 165? you can use 8192 baud data acquisition, not 160 (12x the speed!)
using TunerPro RT, load the datalogger, load the 165_6E definition, and click connect.
provided you have a 10k resister between A and B (which is *required*) you should get data immediately (might take a click or two on "connect").
If you don't get data, your cable is bad.
I have an 89 TA with a 165 and have no trouble getting data using TunerPro RT.
WinALDL is awesome and invaluable for the 160 baud guys, but anyone with a 165 running 6E should be using 8192 baud in my opinion.
Old Mar 28, 2004 | 11:19 PM
Cooter77's Avatar
I'm confused on your 8192 baud...??
Is this the com settings on my laptop..?? becuse it don't have that number as option.
I got the winALDL to work...!!!! Woo hoo..!!
I still can not get the TUNERPRO RT to work. It doesn't connect to ECM. I have chosen the 6E definition and still nothing..
I
Old Mar 29, 2004 | 11:44 PM
Cooter77's Avatar
OK...nevermind i'm a idiot.......I understand the 8192.....
Sometimes i sit here to long trying to learn as much as I can.
JoBy
Apr 27, 2002 07:55 PM
JPrevost
Apr 20, 2002 12:29 PM
JoBy
Feb 9, 2002 06:08 PM
citgofan99
Jan 12, 2002 08:15 PM
