Result of noid light test on my no fuel during crank prob.
Car: Turbo Buick
Engine: 3.8 V6
I got a noid light and it acts exactly like the injectors do. So I guess the injectors are fine.
Im going to have to start looking at the pinouts on the ecm to see what else it needs in order to crank.
Car: An Ol Buick
Engine: Vsick
Re: Result of noid light test on my no fuel during crank prob.
B, we're you running it with the TBI ecm controlling the ignition?.
Do you see a shot of fuel being discharged from the injectors, when you first crank it?. If you see the noid flash at that same moment, but no fuel then in fact you do have an injector problem.
Has the car ever run with the injectors, and .bin you're using?.
If you have spark, and the injectors pulse fuel, then you might try a small shot of starting fluid. That would tell you the cranking AFR is too lean.
