Does the kind of trans you use affect what bin you should start with?
Old Apr 2, 2004 | 09:56 AM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I have been doing my research since I am just starting with reprogramming my eprom. My ecm is 1227302 for an auto (700R4) and 2.8L v6. I was planning on moded the eprom to work with a 3.4L w/ a M5. Is the $3a bin the one I want or is there a better way to go?
Old Apr 2, 2004 | 10:16 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Does the kind of trans you use affect what bin you should start with?
The $3A is known as the maskid. The maskid defines the layout of the calibration data within the EPROM.
It is best to change to a manual bin when changing the transmission from an auto to a stick.
You will still use the $3A mask, just a different BCC (Broad Cast Code). The BCC defines the particular calibration. As an example there can be two different BCC's where the only vehicle difference is the rear end ratio.
As far as which one to use, I don't know what the 2.8l BCC's are. I just looked at Davis's site and the TGO FAQ, and nothing. Hopefully someone can help out.
RBob.
Azrael91966669
25
Jun 20, 2017 04:04 AM
The_Phoenix
Feb 4, 2016 07:10 AM
beachrodder
Aug 25, 2015 08:05 AM
jharrison5
Aug 19, 2015 05:53 PM
mizz0313
Aug 12, 2015 06:45 AM
