Timeing good, Starting not.
Car: 92 Camaro RS
Axle/Gears: 3.73 Truetrac
I got the timeing for my motor where I want it, but my starter dont like it much, it pulls back and grinds before the engine starts. This is a new starter and the old one did it too when I put the timeing where it is now. What can I change in the chip to change the timeing just at startup so my starter dont grinp and wear out to fast.
P.S. 8746 ECM
P.S. 8746 ECM
Car: check
Engine: check
Transmission: check
Re: Timeing good, Starting not.
P.S. 8746 ECM
P.S. 8746 ECM
As a side note, the distributor base timing should be the same as the inital timing setting in the chip.
RBob.
Car: An Ol Buick
Engine: Vsick
When cranking the ecm has nothing to do with the timing. The car is just using the ignition module. Once the engine starts and gets to 400 RPM then the ecm takes control of the timing.
Ghettobird52
Jul 5, 2024 11:18 PM
