programming a 512 from a 256
Old Apr 2, 2004 | 09:23 PM
nhromyak's Avatar
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
I am sure it's in here somewhere, but I have not been able to find it. If someone knows, please respond - thanks.
I got Craig Moates 27SF512 chip and adapters, for my '7730 from Howell.
The chip from Howell was a 27C256.
1) I read the Howell chip switching the PPII for this chip.
2) I read it in winbin with the 7730v3.ecu.
3) Saved the BIN with a new checksum.
4) I used TunerCat to stack the bin for a 512K - right?
(e.g. BIN size = 32K, CHIP SIZE = 512K, Switch Block Size = 32K).
5) I also verified the programming and it checked well.
The truck stays in Limp mode, CEL always on.
Am I supposed to start and stop the programming at a different address? If so where.
Back to searching.
Thanks.
Old Apr 2, 2004 | 10:46 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
First question,
Should the buffer/bin be a 32K file or a 512K file?
Second question, where should the Buffer Start, Device Start, and device end be?
I am using
Buffer Start = 00000
Device Start = 00000
Device End = 0FFFF
Thanks.
I am trying a 32K bin now.
Still searching the archives...
Old Apr 3, 2004 | 12:45 AM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
chip size for a 27SF512 is 64kilobyte (64k). That looks like your problem.
bin size = 32k
chip size = 64k
switch block size = 32k
Oh, and not to be picky, but you used TunerPro, not TunerCat. Nothing against TunerCat. :-D
Old Apr 3, 2004 | 09:36 AM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
YAHHHH :lala:
THANK YOU THANK YOU THANK YOU! :hail:
Yes indeed TunerPro.
I will try it again this morning.
So my start and stops addresses are good?
THANKS!
Old Apr 3, 2004 | 11:54 AM
Mangus's Avatar
Transmission: T5WC
yes. addresses are fine.
angel2794
Theoretical and Street Racing
25
Mar 7, 2026 01:08 PM
djmarch
May 8, 2016 11:32 AM
ULTM8Z
Oct 2, 2015 01:25 PM
f-bodyz28
Sep 2, 2015 05:03 PM
bdads
Aug 24, 2015 06:01 PM
