Injectors: How big is too big?
Old Apr 5, 2004 | 08:31 PM
justme's Avatar
I know there are formulas for figuring out how much injector you need minimum, but when do you get to the point in size where the injectors are too big and they can't be controlled at idle and part throttle? I ran across a set of injectors and was wondering. I pulled the Procharger off in lieu of a decent size turbo and plan on turning up the boost from about 11 lbs to 17 or so. The 42lb injectors had duty cycles up in the high 90's before so I think I am going to go ahead and step the fuel up a little too.
Old Apr 5, 2004 | 10:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
My lil 242 CID v6, has 60 PPH injectors, idles at 750 RPM in gear.
Batch fire mode.
If you look at the Thread Hard Core Data, you can see what it looks like just coming off idle. ie 900 RPM and 60 K/Pa, 2.2 msec PW.
The 60s are rather unique in their behaviour at short PWs.
I have had 55s which are Peak and Holds, also idle well with a modifed 749.
The bigger injectors take more time to dial in, since any given change makes more of a difference.
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
BrianChevy
Wheels and Tires
Oct 13, 2015 12:33 PM
LT1Formula
Oct 8, 2015 08:34 PM
3.8TransAM
Oct 1, 2015 07:47 PM
dusterbd
Sep 29, 2015 08:40 AM
