ecm info needed
Old Apr 6, 2004 | 12:21 AM
c4boom's Avatar
Car: 87 iroc and 88 k2500 tbi truck
Engine: l98 and lo5
Transmission: 700 r4's babby
ecm info needed
what is the dif from the 1228063, 1228746 and 1227747 ecms
is one beter than the other. are the wireing harnesses the same is one more tuner frendly.
Old Apr 6, 2004 | 04:35 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: ecm info needed
The 1228746 is the car version of the 1227747, and as such it uses a IAT sensor. Plus the calibrations are somewhat different since one is for a car and the other a truck. The 1228063 as I recall is just an earlier verson of the 8746.
There all C3s, which are a real early series of GM EFI ecms.
Old Apr 6, 2004 | 04:50 PM
c4boom's Avatar
Engine: l98 and lo5
would i gain any thing swaping out the 747 for one of the other 2
Old Apr 7, 2004 | 06:27 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Depends upon the application. Both the '747 & '8746 have code that the other does not. The '8746 has a lean cruise mode (patch available for the '747), and has SA idle control. This provides a better idle. The '8746 also has some fueling control via an IAT.
The '747 has better AE control. Just right for heavier vehicles.
Both have a patch available to eliminate the forced knock test.
The '8746 has a patch to change the speed limiter to a rev limiter.
I am not familar enough with the '8063 to pro/con it.
RBob.
Old Apr 7, 2004 | 01:59 PM
ssxmac's Avatar
Car: 89 RS
Engine: lo3
Transmission: 700R4 w/ B&M shift improver
Axle/Gears: 3.27 9-bolt posi
i have the 8746 and have heard that it has a slower baud rate when compared to other cars with different ECM's (speciffically cars with TPI). If i understand correctly then this means that it is harder to tune with this ECM. Would i gain anything by switching to a faster ECM? (gain meaning makeing tuning easier/quicker/more efficient, not HP). If so, which ECM(s)? Im getting the prominator soon and this info would be great.
-chuck
Old Apr 7, 2004 | 09:49 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
Let me add one to the question : 1228062 It's what my S-10 has in it. I know the pinout is nearly identical (if not the same as) with a 747.
Mainly just curious!
Old Apr 8, 2004 | 07:02 AM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
I'll ask one too...
Where are these patches you are talking about? That rev limiter thing would be great.
Old Apr 8, 2004 | 08:10 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Originally posted by jeepguy553
I'll ask one too...
In the stickies above look for the 'patch method demo' thread. Two nice patches for the '8746 in there. . .
RBob.
IROCZ1989
Jan 24, 2016 03:55 PM
355tpipickup
Aug 19, 2015 10:02 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
