Rt_tuner
Old Apr 8, 2004 | 08:32 PM
TTOP350's Avatar
Engine: 4++,350 & 305 CIs
Rt_tuner
OK, I have all the stuff and I can't find any tuning tips for the RT tuner what am I missing??? ( I have done searches,no luck)
My car is a 89 big cube small block W/ afr heads Mini ram Maf thanks
Don't burn me to bad I'm new to tuning
Old Apr 9, 2004 | 12:29 PM
TTOP350's Avatar
THANX FOR THE HELP
Old Apr 9, 2004 | 12:31 PM
Ronny's Avatar
read all the stickies above? i have a speed density so cant be of much help. i was told to start datalogging at idle and off idle and then drive car on level surface at moderate speeds b4 trying any heavy pedal. datalogs will tell you what you need to change in eprom. i started getting my blms in line day one and then worked on AE(remove stumble) and PE. PE was a guess that turned out to be accurate on dyno.
Old Apr 9, 2004 | 02:06 PM
TTOP350's Avatar
Thanx for the reply,I knew someone would respond to that......... HA HA..I really need to know more about the MAF Table on the RT- cause it looks nothing like the on in the posts above...
Old Apr 9, 2004 | 08:06 PM
Mangus's Avatar
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
I'd be willing to be he didn't respond because of your sarcastic, unnecessary, and pointless all-caps post.
Meanwhile, tuning with the emulator is pretty much the same as tuning without, only much faster. The same rules apply. Take your time, take notes, and make small changes.
Old Apr 11, 2004 | 02:53 PM
TTOP350's Avatar
Sorry about the all caps, I was on the Dyno computer and didn't switch....I fell asleep in typing class
Anyway the maf tables(airflow gps) is not the same(or i can't find'em)..I can only find one row of tables
Dmitri
Nov 18, 2005 05:41 PM
