Question about LV8 counts, MAF tables, etc
Old Apr 9, 2004 | 05:25 PM
Jerriko 3.4's Avatar
Car: 1987 Firebird Formula
Engine: 3.4L 207 V6
Transmission: T5 W/C
I have a 302 ecm and $3a definition file. I am running it with a 3.4L cammed motor. I have modified it with the throttle body off of a TPI setup. I am using the 24lb injectors. Currently, the ecm is throwing the code for too much airflow through the MAF. The airflow required is greater than what the eprom was programmed with. I have been playing with the MAF tables. I have many questions:
In the MAF tables, should I increase the gms/Sec per LV8 count?
Should I change the gms/Sec in the Maximum Air Flow vs rpm?
Will I need to adjust the pulse width multiplers and other related tables?
Any help is appreciated,
Jim
Old Apr 9, 2004 | 07:23 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
You need to find the diagnostic parameters within that mask ($3A). What happens is that an airflow parameter vs RPM vs TPS is exceeded and it throws the code. Changing and one of or all of the diagnostic parameters will fix it.
Here are the MAF high parameters from the '165 $32 code:
Code:
	;       error # 33 Params
	;       >> MAF Sensor Hi <<
	ORG     $C203
LC203:	FCB	38	; If TPS >= 14.8%, set error #34
			; CALIB = Arg * 2.56
LC204:	FCB	45	; If Air flow <= 45 gms/sec
			; disable error #33
LC205:	FCB	96	; If > 0.6 Sec, Set code #33
			; CALIB + Arg * 160
LC206:	FCB	8	; 800 Msec error 34 Min time req.
			; CALIB = Arg * 10
LC207:	FCB	128	; If RPM > Disable #33
			; RPM/25
LC208:	FCB	100	; 10.0 VDC PUMP VDC FOR error 33 ENABLE
This is just to give an idea of what needs to be changed. The V6 ECMs have little support and even less of a knowledge base.
RBob.
Old Apr 11, 2004 | 10:06 AM
funstick's Avatar
yes but to do so youll need to change the scalar for that table. get with me via email. or hell if your willing to make the drive i live just north of novi in michigan west of pontiac in a small town called white lake. i see your in rockford a 3-4 hr drive. i have lots of experience with $3a
chazman
Aug 28, 2018 03:25 PM
Bert87
Aug 23, 2015 03:50 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
