Help with '7730 VEs
Old Apr 12, 2004 | 04:36 PM
nhromyak's Avatar
Car: '73 Chevy Blazer
Engine: BBC - 408
Transmission: SM465
Help with '7730 VEs
Background - '7730 - Holley 4 Barrel TBI - from Howell, no spark control (e.g. mechanical HEI).
I am using TunerPro with 1227730_8dm.ecu
This was originally a 350 automatic trans prom from Howell.
Now it's sitting on a 409 BBC in front of a manual transmission.
I have read Traxion's Part throttle VE tuning
https://www.thirdgen.org/techbb2/sho...threadid=39254
What I have done
I left Howell's original BPW alone, assuming it is correct.
I had to take out almost 10 points from almost all the tables in the lower and upper VEs to get 128 BLMS, two or three LOWER VEs are still running as low as 124 when I decellerate.
Is this "close enough"?
My thoughts
As I am currently running a mechanical distributor with changed springs and adjustable vacuum, Should I be trying to get the most vacuum at part-throttle and rpm cruise with 128 BLMS?
I thought maybe I need more advance, but then my vacuum went down (KPAs went up) all across the rpm range. While my BLMS went down (120s).
Do I still need to lower my VEs? Even though the spark was advanced? Or should I back off the ignition now that I lost vacuum move on to the more exciting AEs and PEs?
The pump shot is really far off. It's almost to the point of the engine dying.
Thanks.
Old Apr 12, 2004 | 05:37 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Tuning a VE table to match a mech distributor is going to be off, from what any chip guy would expect. You can't get a mechanical distributor to do the things you can do with timing in code.
Trying to get injectors to act right with 1/2 voltage maybe challenging. yes, the AE might need alot of work.
Old Apr 12, 2004 | 06:14 PM
nhromyak's Avatar
Engine: BBC - 408
Transmission: SM465
Thanks for replying.
So, am I shooting for as much vacuum as I can get with both spark and VEs at 128?
BWilcox
Sep 20, 2015 12:19 PM
mddaniel
Sep 8, 2015 05:16 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
LBSZ28BLOWN
Jun 12, 2002 03:29 PM
HighHopes85
Jun 8, 2001 05:21 PM
