Idle AFR vs Vac constant ($61)
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
Found at location 0x0233 in the $61 code...is this added or subtracted from the AFR calculated using the VE tables?
Thanks!
Thanks!
Car: check
Engine: check
Transmission: check
Re: Idle AFR vs Vac constant ($61)
Thanks!
Thanks!
RBob.
Car: check
Engine: check
Transmission: check
So changing it won't do a thing for me once the engine is warmed up?
RBob.
Car: 1980 Jeep CJ7
So all the tuning I have done in the idle area of the VE1 table is valid? Good. That means my nice pretty BLM table is done right...I hope. The range of about 125 to 128 looks good to me. My main idle cell (800rpm x ~40kPa) is sitting solid at 128 and the corresponding INT is at 128 too. The ones around it are 126-128.
i guess I can just play with the Idle AFR vs Vac constant to get the excess fuel out of the startup and warmup period.
