arap 6e .bin
Old Apr 27, 2004 | 02:40 PM
mikobu3's Avatar
arap 6e .bin
i am using this for my modded 86 305 tpi , i am having alot of difficulties getting tuner pro to work , i am new to all of this and have done alot of reading , if there is anyone out there that no;s how to do this stuff please pm me i will pay you for your help ,
thanks
Old Apr 27, 2004 | 02:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
What specifically is the problem?.
Give us a few details about your engine combo, and what you've done, and what's happened. Don't try to list everything in one post or it gets awkward. Start with like idle, or cruise and what you have going on.
Old Apr 27, 2004 | 04:02 PM
mikobu3's Avatar
hello grumpy
ok i got a 1986 305 tpi transam comp cam xe 212-218 449 -456 112lsa i also ported the 416 heads and put bigger valves in there 1.94 , 3.42 gears , dynomax headers , got rid of some emissions ,
grumpy my car seems to run fine but i no its pretty lean , i just got it back from mechanic , i am trying to get my chip burning goin but i haven;t got to far
hope this helps a little
and thanks
Old Apr 27, 2004 | 04:30 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Engine: 1 BA 305 TPI
Transmission: Probuilt 700R4 - 2800 Stall Midwest
What kind of problems are you having with TunerPro?
Old Apr 27, 2004 | 04:47 PM
mikobu3's Avatar
to be honest with you , i have no clue how to open the bin up in there to make a few changes , i am a rookie , but i;m sure if i was teached well this would be a piece of cake to do
thanks
Old Apr 27, 2004 | 05:00 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
Start by selecting the ECU from the dropdown menu at the top right. You should probably select the 6Ev011 ECU file. Next open the bin under the "File" menu or just hit Ctrl+C. Select the arap bin. That's about it. The bin should be loaded for editing.
Old Apr 27, 2004 | 05:08 PM
mikobu3's Avatar
i do not see the 6evoll ecu file in that list ,
Old Apr 27, 2004 | 05:18 PM
jfreeman74's Avatar
Car: 1985 Iroc-Z
You have mail.
antman89iroc
Apr 29, 2008 09:16 PM
dyeager535
Jun 22, 2003 04:01 PM
Neil
May 24, 2001 09:24 AM
