Will this work on piggy-back memcal setups?
Old Apr 27, 2004 | 11:07 AM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
I'm in the process of gathering the gear necessary to read and program my own chip for my 383 Super Ram setup. I've already bought Datamaster.
As far as programmers and editors go, will they work to read the current setup (BIN) off a piggyback chip setup? When I say "piggyback setup" I mean one where someone sends you a chip board that you plug into your ECM and then plug your original memcal into the board they sent you. If possible, I want to see the spark and fuel tables currently being used as a starting point to doing my own.
Have a Great Day!!!
- Vern
Old Apr 27, 2004 | 01:50 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
https://www.thirdgen.org/newdesign/tech/promintro.shtml
As you read through that, make sure you click on the links showing pictures of the various adapters.
Old Apr 27, 2004 | 03:24 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Start with the above link: I have had good experience using the Moates software (ver 8.50 or 8.51) to "pull" the bin through the ALDL and "dump" it into an actual bin file.
I had ordered a chip from Fastchips (Ed Wright) and wanted to use it as a base for my own tuning.
I believe that is what you want to do, but I am not sure if the Moates will pull through the piggyback adaptor....
HTH,
Old Apr 27, 2004 | 03:30 PM
Dave_Jones's Avatar
In particular, note this one:
https://www.thirdgen.org/newdesign/t...om/1138134.jpg
It shows a method for reading a stock memcal.
If you want to read what's in the chip on a piggyback adapter, just mount it the same way.
I've never tried dumping one with Moates.
Old Apr 27, 2004 | 10:08 PM
vernw's Avatar
88TPI406GTA is pretty close on what I want to do...
What I'm actually wanting to do to help learn and better understand this whole process is to watch what Jeremy Formato does and changes (and try to understand why) as he fine tunes his custom prom for 383 SuperRam setup. Figure watching an "expert" is the best way to better understand it all. Since I'll have the Datamaster files (I bought it last week to do the logs for Jeremy to use for prom adjustments), I think all I need to do is see what he changes and then understand (or ask him) what a particular change did or does.
I'll look into the link again (did it earlier) and see if I can see where/how to pull the BIN through the ALDL to create a BIN file to look at in TunerPro. I didn't see it the 1st time, maybe I'll see it after looking again. I'm hoping not to have to buy a programmer (or the Prominator) just yet.
Have a Great Evening!
- Vern
Terrell351
Jun 13, 2021 01:13 PM
Eric-86sc
Apr 3, 2016 03:52 PM
gta90
Sep 15, 2015 04:00 PM
masonta
Aug 31, 2015 10:14 PM
Street Lethal
Aug 13, 2015 08:28 PM
