Lowering Fan Turn On Temp
Old Apr 28, 2004 | 08:49 AM
gchu's Avatar
Car: 88 Iroc Convertible
I've read most of the articles on the site about how to DIY proms and it sounds "simple". Appears I should be able to start programming chips for under $200.
Here is the question - the only thing I want to change is the temp the primary and secondary fans on my 88 Iroc 305 TPI come on. I know the secondary fan is controlled just by a switch, but I wanted to change the primary as well - which is controlled by the ECM.
Once I get the hardware and software, how hard is it to change the temperature. Will it be obvious? Meaning there will be a message/prompt saying: Fan Turn On Temp xxx F and all I have to do is type over it and then burn the new BIN onto the chip?
Can someone post a screen of what it would look like? With the info regarding what software they are using.
I had bought a hypertech street chip off of Ebay but it sounds like I wasted my $25 - since it didn't lower the fan turn on temp (apparently I needed to get the track chip for that). If I get the programming setup, my strategy was to just reprogram the hypertech chip (after saving the original bin first).
Any thoughts?
Old Apr 28, 2004 | 09:18 AM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
Using TunerPro for a 89' the Constants are:
Minimum MPH for using Fan 1 Duty Cycle Table
MPH for Fan 1 Turn On if A/C On
Minimum Fan 1 Time On
Fan 1 Duty Cycle if MPH < Minimum and A/C Pressure High
Fan 1 Turn on (A/C on)
Fan 1 Turn off (A/C on)
Fan 1 Turn on (A/C off)
Fan 1 Turn off (A/C off)
just my .02
Old Apr 28, 2004 | 12:31 PM
jonarotz's Avatar
Car: 91 Z28
Hey MTPFI-MAF what ECU are you using?
Old Apr 28, 2004 | 04:34 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I am using the 6Ev011 that came with TunerPro RT 3.06
RazorN8
Jan 7, 2022 11:44 AM
9192camaro
16
Feb 3, 2019 12:21 AM
italiano67
Dec 11, 2016 09:21 AM
sweet_87_iroc
Exterior Parts for Sale
Mar 27, 2016 04:05 PM
