749 $58 hac (want to participate?)
Car: 1987 Z28
Engine: 383 Single Plane EFI-NOW RUNNING!
Axle/Gears: Not there yet...
Humor a noob, please...........
This is all really exciting. It looks like I picked the right time to get into ECM tuning. This all makes me wonder if I shouldn't have waited about doing the '730 swap and just went with a '749, even though I'm N/A.
**Silly question alert**:
I assume that this ECM can be made to work on a N/A application? Seems I've read some things that would indicate such. If so, I may build an adapter harness to A/B the '749 & '730 on my car. Hmmmmmmmmm........
Car: An Ol Buick
Engine: Vsick
Originally posted by AmorgetRS
From what I've read if you aren't gonna boost the 730 is better code or at least easier to work with then the 749.
And once your dealing with source code, if better routines are found they are patchable into it. So even if your statements were true it's mote since because of the code being patchable. If you were to look at the source code I've posted, you'll note there is a huge amount of code space to work with.
Car: An Ol Buick
Engine: Vsick
Re: Humor a noob, please...........
The 58 code was justed in N/A applications.
Grumpy -
I was mostly reffeering to the injector constant not working and IIRC the fact that, this is straight from the FAQ:
Additionally, the fueling code is based on BPC/BPW funtions vs
ideal gas law math on $8D. $8D is a lot more "refined" on a N/A setup, but obviously after 100kpa it
is useless.
Correct me if I am wrong about those two things...
is useless.
Car: check
Engine: check
Transmission: check
I say 'almost' because the '749 doesn't have the output for the TCC/Shift-light of the $8D mask. If running an auto w/a a TCC then the $8D in a '749 is a bad idea.
The A/B harness is only required for switching masks, not the ECM.
The best thing to do is to pick a mask that fulfills the engine requirements and learn it.
RBob.
Car: An Ol Buick
Engine: Vsick
is useless.
is useless.
Refined, doesn't always mean better. And as of late, I've found that having more resolution will more then make up for the difference from a gas law calc, to TBI form of calc. With the cource code being available a simply creating a new look up table with increased resolution can put the 58 code miles ahead of the 8D in that reguard. The Subject here is about source code, so the stock limitations only apply to all the other non source code available codes, with source code, the picture now completely changes.
Simple code done cleverly is now the key, IMO. Simplier now just means it makes the tuning easier. Given enough resolution even rather primitive code, and strategies can be made to work very well.
Stay tuned, there's some neat new stuff just around the bend. Now, we just need to get more people active in working with this.
Car: 1987 Z28
Re: Re: Humor a noob, please...........
Originally posted by RBob
It isn't so much of a question as to which ECM to run, as it is a question of which mask to run. The $58 mask runs just fine in a '730 ECM. Whereas the $8D mask almost runs just fine in the '749 ECM.
RBob.
RBob.
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
The only reason (I've found) to go 749 is the need for dual injector drivers that can handle 8 P/H injecotrs if they are replaced.
/N.
/N.
Car: '99 Trans Am, '86 Camaro
Engine: LS1, Scrap
Transmission: T56, T5
Axle/Gears: 3.42 Stock ZT, 3.42 Open
A $58 definition Mechanic can't claim is his! Yay!!! (though history says he'll do it anyway, and the file will be banned from TGO to avoid even an impossible to win lawsuit, and even fewer people will ever consider purchasing a product made by such a ... I can't say those words ... has anyone bothered to tell Mechanic how much potential business he's lost over this?)
:hail: Grumpy :hail: RBob :hail:
xbmx89
South Central Region
Oct 31, 2015 10:59 AM
Linson
Oct 1, 2015 09:50 PM
