Idle problem
Car: 1989 Camaro
Engine: 383
Idle problem
Ok, I have been reading and reading and oh yea reading.
I posted a while back about my car having a high idle for a few seconds when I come to a stop. I did a search on "throttle follower" but it seams thats not for 165 ecm(or at least I can't find it). I read one post that was taklking about the DFCO settings on a 165.
What does DFCO stand for? Could this be where I need to tune?
Also is there throttle follower for the 165?
I'm using TunerPro, AYPY bin and 6Ev011 ECU file.
Car: '89 Trans Am WS6
Transmission: T5WC
Axle/Gears: 3.08 posi
DFCO stands for Deceleration Fuel Cut-Off. It is not what is responsible for what you describe.
DFCO causes the injectors to shut down when the car is coasting and is a fuel-saving device.
Car: check
Engine: check
Transmission: check
There is another thread that is on the same subject "high idle while coasting", may want to keep an eye on that one too.
Can you post a short section of a data log during coast down? From 15 MPH to a stop.
RBob.
RBob.
