02 sensor and misfires
Old May 19, 2004 | 11:49 AM
11sORbust's Avatar
I have noticed the wideband does not read unburnt/raw fuel through the exhaust. I think depending on the condition, misfires can show up a lean reading on the meter. Would that be correct?
Old May 19, 2004 | 12:19 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 02 sensor and misfires
It depends on how much the WB output has been filtered. At low engine speeds a single cylinder with a lean misfire (such as just after a cold start) is easily seen as a lean spike. If heavily filtered that spike may be lost.
At higher engine speeds a lean condition on all cylinders (not enough fuel) can have a WB bouncing off the rails. It will show from greater then 25.5 AFR to less then 10.0 AFR and back and forth.
RBob.
Old May 19, 2004 | 01:12 PM
11sORbust's Avatar
Ok, well I was messing with my cold start trying to get the a/f right. The wideband reports 20.0 as my mixture the whole cold start(no matter the pulse width). I suspect it is lean misfires caused by my old plugs.
On a sidenote my friend was having problems with his car backfiring through the intake under heavy load cruising(t-56/MR). I tuned the chip so the fueling didn't change. There was a few holes in the main spark table in the 85-100kpa area @ 1000-2600. I fixed the timing and the bog/pop was gone. Now that I look at the log data, the blms are very lean. I know the ve tables are really, really close. Nothing was changed since the last time I logged data. So I'm thinking misfires will show a false lean condition on the narrowband O2(just like the wideband). In turn I think he needs new plugs...... they look a bit old and glazed. Rest of ignition is fine.
So do you agree that a fouled plug can create a false lean through an O2 sensor?
Old May 19, 2004 | 01:33 PM
87_TA's Avatar
Tim, when I have bad plug wires causing a missfire the would instanly show on WB and stock o2 as a lean condition because of the unburned 02.
Old May 19, 2004 | 03:01 PM
11sORbust's Avatar
that is exactly what I thought. Didn't want to ASSume it though. Very important thing to know
So how is the t/a doing?ever bust a sub 1.5 60ft?
Old May 20, 2004 | 06:06 AM
87_TA's Avatar
NAA , NOT YET.
The converter that I sent back before that TCI said there was nothing wrong with finally stopped locking all together. grrrr
Also found it was stalling around 5100 - engine is over powering it.
That would explain why it won't hook - I have since installed 90/10's and hoosier 27 x 11.5 QTP's and still no good, If you leave soft it pulls wheels real nice - then spins.
I have made about 15 passes this year , Not one pass have I not spun from stk susp. to where I am now.
If you leave hard its all spin before any transfer takes place.
So now they are sending me a brand new Super street fighter with a 12" lock disc that weighs 4 lbs more . That converter is rated around 3800 but should give me about 4200 at full torque seeing as how I was stalling later on the other 2.
Just hope that 4 lbs on crank does not hurt me.
Its so fun pulling out your tranny about 6 times a year. The up side to that is I got her down to below 1.5 hrs to change a converter.
Hmm, wonder if John Force is looking for a tranny changer
NZKnight
Oct 15, 2015 02:47 PM
aaron7
Sep 30, 2015 09:15 AM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
dusterbd
Sep 29, 2015 08:40 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
