Mask/Bin IDs
Old May 20, 2004 | 03:01 PM
88TPI406GTA's Avatar
Car: 2009 Pontiac G8 GXP
Engine: LS3
Transmission: 6L80E
Mask/Bin IDs
For some reason, I can't find a list of these when I search.
I am looking for a list of what was available by the four letter code and application.
I am looking to switch to SD from a DFI setup or at least have plug and play capability...
the setup is a stockish tpi 350 and a t-5. Ideas for a starter? I had looked at the Super AUJP, and after reading the thread am still not sure it would be decent for a stick car.
Any input welcome.
Thanks,
Old May 20, 2004 | 04:08 PM
AlexJH's Avatar
Engine: 5.7L V8
There used to be a list that was freely available, but someone was using it to sell chips so it got taken down.
What about using a 90-92 fbody with a 305/T5 combo - call up the dealer and ask for a memcal, ask them what the latest version is?
Old May 20, 2004 | 04:12 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: Mask/Bin IDs
Any input welcome.
Thanks,
Maybe one of the Corvette bins would be a good start. AXCN comes to mind. That is a 6-spd 350 TPI calibration (there are no stick 350 f-body bins).
The other way would be to start with a 305 stick f-body bin.
In the TGO tech section there is a list of BCC's and vehicles.
edit: here is the TGO link and another good site for BCC info:
https://www.thirdgen.org/newdesign/faq/thirdgen.shtml
http://www.eecis.udel.edu/~davis/z28/.
RBob.
Old May 21, 2004 | 12:53 PM
89350STRO's Avatar
Not sure if it's what you're looking for but try this link out. It's a searchable database of BIN files.
http://www.efitune.com/broadcast_codes/
89350STRO
Old May 21, 2004 | 03:17 PM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
89350STRO
Thanks for the link! That's awesome!
Old May 21, 2004 | 03:52 PM
Engine: LS3
Transmission: 6L80E
That link is exactly what I was looking for...
Thanks!
