PCM info
Old May 23, 2004 | 05:27 PM
rpm's Avatar
rpm
PCM info
What is the PCM calibration file I need to find for my son's 97 LT1 with automatic transmission and a/c? Thanks
I am also interested in knowing what software exists to reprogram it.
Rod
Old May 23, 2004 | 05:35 PM
87Formula4bbl's Avatar
Car: '87 Formula
Sorry to disappoint you rpm, but I doubt you will find the answer to that question on these boards. May as well here it from me cause I know someone else will tell you, this is a third gen F-bodies tech only forum.
Old May 23, 2004 | 07:25 PM
rpm's Avatar
rpm
Thanks for your thoughts and I understand, but you never know. I appreciate the info.
Rod
Old May 23, 2004 | 08:31 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
There's enough thirdgens that have had LT1's swapped in, that it's not entirely off topic, IMHO. But, you'll probably find more info by searching through the fourthgen message boards.
'96-97 LT1's were OBDII, which makes reprogramming an expensive proposition. Most DIY'ers convert to OBDI, which makes reprogramming easy. It's a very easy conversion, simply replace the PCM, and either change the knock sensor to the OBDI type, or add a 3.9K resistor in parallel with the '97 knock sensor. Instructions can be found on the web.
Once you convert to OBDI, you scan with FreeScan, or DataMaster, and reprogram with TunerCat. You'd want to use a '95 program to start with, rather than a '94, for compatibility with the '97 transmission.
Might want to check out the following sites:
http://www.tunercat.com/
http://www.akmcables.com/
HTH,
Old May 23, 2004 | 09:04 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: PCM info
96 on is OBDII, as mentioned.
If you were to wire in a 95 PCM, ie the 8051, then there's a *normal* way of reprogramming it using www.Tunercat.com 's stuff. Thou you need some special cabling. When doing the flas type PCMs, I always grab a spare, and do the programming on the bench. They can crash during reprogramming, and are a project to reset.
Fanatic1074
Oct 3, 2022 05:57 AM
3rdgenparts
May 21, 2016 11:50 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Linson
Oct 1, 2015 09:50 PM
