Knock counts
Car: Firebid Cab-92/1989 TTA
Engine: 383 HSR TPI
Transmission: TH700r4
Axle/Gears: 4.10
Knock counts
Hi!
I am getting knock counts when idle driving and the aldl tells me that 1 and 2 cylinder gets knock counts at 800 rpm and 3200rpm where can i start my trubbleshoting,please let me now if you have any answers.
Thanks!
Thanks!
Car: An Ol Buick
Engine: Vsick
Re: Knock counts
Originally posted by Firebird sweden
Hi!
Thanks!
Hi!
Thanks!
And you need to make sure it's not a noise that the ecm just thinks is detonation.
If it accurs during a transistion, then you need to pull some timing, or add some fuel to stop it from BEGINNING. If you just add fuel or yank timing at the exact spot you see the counts, you'll never get rid of it.
Car: check
Engine: check
Transmission: check
Re: Knock counts
Hi!
Thanks!
Hi!
Thanks!
The knock modules (ESC module) used in the '88-'90 TBI setups are not that good and will report knock when there isn't any.
Is the reported knock random and scattered about in the MAP vs RPM range, or is it always in one location? What scan tool are you using?
RBob.
RedLeader289
May 28, 2019 01:47 PM
bigjay89gta
Oct 15, 2015 08:04 AM
efiguy
Sep 27, 2015 01:30 PM
