BPC calcs with $88 help needed
Old May 31, 2004 | 02:16 PM
WHITE87GTA's Avatar
ok so i have decided to go with the $88 mask using the atds.bin as my starting point.(3400 v6 DIS SD transplant engine) i just discovered that the injectors in the car have been changed to 22#(should have been 15# injectors by what i have found). i am using tunerpro editer and in the constants table it shows the bpc as 48. when i did the calculations based on the formula BPC= 1461.5*(VOL/RATE) i get 204.1 (3.4L/6cyl / 22# x 453.6g/lb/3600)
when doing calcs based on what should have been in there i get 299. why such a large difference when in the editor constants it shows 48? am i on the wrong constant for changing bpc?
is this how to change for the larger injectors?
Old Jun 1, 2004 | 03:04 PM
WHITE87GTA's Avatar
is there anyone that can help with this?....
Old Jun 1, 2004 | 04:43 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
There are two injector constant terms and one injector constant table in the $88 mask.
Code:
L86BA	FDB	0608	; idle injector constant
L871F	FDB	12288	; math constant, (12,288) N-Alpha fueling
; Injector Constant vs. EGR airflow
; BPC
; PFI:
; Val = 730.75 * (VOL/RATE)
; VOL = Vol of 1 Cylinder in liters
; RATE = Injector flow in gms/sec
; convert: #/hr = (gmSec / 453.6) * 3600
; convert: gmSec = (#/hr * 453.6) / 3600
; 3.1l / 6 = 0.516667 l/cyl
; 16.5#/hr = 2.08 gmSec
;	;	BPC	; airflow
L8754	FCB	182	;   0
	FCB	179	;  16
	FCB	176	;  32
	FCB	173	;  48
	FCB	172	;  64
	FCB	167	;  80
	FCB	162	;  96
	FCB	160	; 112
	FCB	158	; 128
	FCB	153	; 144
	FCB	151	; 160
	FCB	151	; 176
	FCB	151	; 192
	FCB	151	; 208
	FCB	151	; 224
	FCB	151	; 240
	FCB	151	; 255
I have no idea how TC converts BPC values.
RBob.
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
Armored91Camaro
Aug 12, 2015 09:41 AM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
