VATS disable at 8746
Old Jun 2, 2004 | 03:18 PM
RosiRonja's Avatar
Hi folks!
After an engine swap I have to disable the VATS in the PROM.
I use the AXKW bin.
tuner Pro shows me with the 8746jonprevost61h.ecu two item for VATS. called VATS freq at the constants.
isn't there a flag to switch VATS off?
What will I have to change to disable VATS?
I tried to find an simple answer in all that older postings, but I´m more confused than before.
Or do you have a AXKW with disabled VATS?
Many thanks
Rosi
e-mail
Old Jun 2, 2004 | 05:51 PM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: VATS disable at 8746
Originally posted by RosiRonja
Hi folks!
I use the AXKW bin.
Many thanks
Rosi
e-mail
Look for this ECU entry:
/* Flag 3: Options @ 0x0007 */
/*|| b7- check box for shift light, else tcc
b6- VATS enable
That is the flag to flip.
RBob.
Old Jun 3, 2004 | 01:55 PM
RosiRonja's Avatar
Thanks for advise.
I found the flag.
Will try a soon as my PROM burner ready to is run again
Rosi
Old Jun 3, 2004 | 10:01 PM
Z28GEN3's Avatar
Engine: 305TBI
Axle/Gears: B&W 9 Bolt 3.73
just delete b6?
Old Jun 4, 2004 | 02:41 AM
JPrevost's Avatar
Car: 91 Red Sled
Originally posted by Z28GEN3
just delete b6?
Turn b6 (aka bit 6) from a 1 to a 0.
Use windows calculator to change between Hex and Binary and back.
8-bit's is 10101010 <-- has 8 bits while 101 <-- has 3 bits.
Old Jun 5, 2004 | 11:29 AM
Z28GEN3's Avatar
Engine: 305TBI
oh! ooops
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
Winchester1094
Sep 15, 2015 09:48 AM
