a/c
Old Jun 3, 2004 | 05:30 PM
11sORbust's Avatar
a/c
I'm still running mafless but have switched to 6E code. Just charged my a/c with 134a. The only problem is the car builds heat with the a/c on. I have a good air dam and blocked the condenser to core support "holes"(that air gap on side of condenser).If the car is moving then it can maintain coolan temp. Just at/off idle it will build heat. I suspect that is a slightly clogged radiator(didn't check the cores). OR the ecm is adding timing for a/c. Does the ecm add spark for a/c?
Old Jun 3, 2004 | 05:32 PM
11sORbust's Avatar
this condition only happens with a/c on at idle.
Thanks for any suggestions....
Old Jun 3, 2004 | 07:04 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Should fill roughly with 75-80% r134 as the system had with r12 if doing the conversion...
Also Vader has posted the most applicable orifice tube for our cars when doing the r134 swap.. (tonna have to search i cant find it quickly). this might help u out on pressure buildup.
later
Jeremy
Old Jun 3, 2004 | 09:37 PM
11sORbust's Avatar
how would that help???
Old Jun 3, 2004 | 10:32 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
No timing change that I can remember, but the IAC counts go up.
Might look at how your MAP changes with the A/C one, and then look at if the timing, and VE change much.
At idle the A/C is a huge load. While only 5-8 HP, that's alot at idle RPM.
Might pull the weatherstripping off at the back of the hood, and see if that allows the hot under hood to better vent.
Old Jun 4, 2004 | 09:20 AM
11sORbust's Avatar
I'll try that.
Was also thinking about removing the underhood insulation. But I'm thinking it'll dry out/fade the paint on my hood. At least I could make the hood vents functional.
I'm running mafless with this car(t/a stock 305). So checking the load is not possible. Guess I could check the aldl for timing increase. Maybe running on default tables might not be good enough...ecm cant see the additional load. WHat do you think?
jrdturbo
Mar 31, 2016 02:58 PM
2012sergen11
Oct 13, 2015 07:38 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
BLK87Z
Sep 18, 2015 11:29 PM
Mdenz3
Sep 17, 2015 08:36 AM
