MAF tables in TunerPro
Old Jun 10, 2004 | 07:42 PM
Greg's Avatar
Car: 89 Formula T-Top
Engine: 388 MiniramII
Ok, I don't understand this and doing a search didn't clear it up really. There's 6 tables and each one ends and begins in a value equal to the beginning or ending in the next table. For example, my table 1's highest value is 1.46 volts and table 2 starts with 1.46 volts. My question is shouldn't the grams/sec in table 1's 1.46 row match tables 2 grams/sec value at 1.46? Mine do not.
Old Jun 10, 2004 | 08:55 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: MAF tables in TunerPro
I've split the entries so that they didn't match, and didn't notice a difference, but supposedly you want one table to merge smoothly into the other.
If I understand you last question correctly, No, they will vary depending on wheither your adding or removing fuel.
Old Jun 10, 2004 | 09:03 PM
Greg's Avatar
So let's say that i wanted to change the gram/sec at 1.46 volts, should I mostly be concerned with what table #1 says it is or what table #2 says?
Old Jun 11, 2004 | 07:59 AM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
If 1.46 is the last entry on table one, and the first entry on table 2, you'd want to change both.
Old Jun 11, 2004 | 08:25 AM
Greg's Avatar
Yes, that is exactly how it is(1.46 is the last entry on table one and the first entry on table 2) and I thought I should change both as well. But the numbers (grams/sec) on the tables don't match though and that's confusing me. I compared the bin to arap and apyp and they don't match either actually. So what number is the ecm going to go by...table one or table two?
Old Jun 11, 2004 | 12:03 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
I'm not sure how TunerPro does the math.
But you have the table entry, and scalers to contend with.
Table entry times table scaler divided by 255, gives you the gm/sec..
You might want to write them about how they're doing the math or just do it all in a hex edit.
Old Jun 16, 2004 | 03:11 PM
Twilightoptics's Avatar
Car: '87 IROC-Z/'82 RX7
Engine: SBC 355/1.1L Rotary
Transmission: T56/5 Speed
Axle/Gears: 4.33/3.93
I didn't notice a difference with them match or separate... but since they are given the same voltage, I would keep the gm/sec the same in each table.
Mark_ZZ3
May 24, 2018 01:02 PM
BumpaD82
Feb 26, 2016 02:57 PM
racereese
Oct 3, 2015 03:46 PM
ULTM8Z
Oct 2, 2015 01:25 PM
