FINALLY can log data with CMoates Software, how to use?
Old Jun 17, 2004 | 08:07 PM
AC's Avatar
AC
Car: Used to drive a camaro
I searched and didn't really find what I was looking for. I'm able to now log using CraigMoates ECM data logging software. How do I use the data I now have? Am I supposed to burn this log onto a chip to be able to read in say tunerpro? Help the newb. Thanks people.
Old Jun 17, 2004 | 09:03 PM
SBNova's Avatar
Now I havent used tuner pro RT for scanning, but as far as most go- the scanned data you collect is for your review, to interpret and make changes to your current bin file. Your bin file is the data burned on your chip- whether stock or aftermarket. You would load your bin file into tunerpro, make changes, and reburn this "new" bin file to your chip (or preferably a new/different/spare chip). Insert this new chip into your car, and repeat.
BTW- all this info is in the stickies at the top of the DIY PROM section. Read ALL OF IT a few hundred times like I did and it will START to make sense.
Old Jun 17, 2004 | 09:08 PM
AC's Avatar
AC
That's what I originally thought. I guess I'm really asking what do I view the log file with? A simple windows notepad or is there software that organizes the log for you?
Old Jun 17, 2004 | 09:19 PM
clippjr8's Avatar
any spreadsheet will work. Just drag and drop the datalog on the spreadsheet and it will open it for you to view.
Old Jun 18, 2004 | 02:54 AM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
There is also a program called Panalyze that's intended for sorting and analyzing ALDL data logs. Doing a google search should locate you a copy for download.
Having said that, I mostly use Excel. Your Moates ECM s/w will save the data as a .csv file, that you can open as a spreadsheet. Once it's in Excel (or any decent spreadsheet program), you can sort, graph, and analyze it to your heart's content.
Old Jun 18, 2004 | 03:53 AM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
For a quick overview of the scan I use panalyzer and for more analysis I use excel, see here for example of diagram from moates software to excel...
https://www.thirdgen.org/techbb2/sho...hreadid=246142
/N.
Falcon50
Aug 22, 2020 03:26 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
bjpotter
Oct 4, 2015 07:48 PM
Aaronv808
Members Firebirds
Sep 30, 2015 12:55 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
