Logged scan
Old Jun 20, 2004 | 11:42 AM
shaggy56's Avatar
Car: 71 Nova
Engine: Superramed 383, Topline heads
Axle/Gears: 8.2 posi 3.08
Logged scan
Well I logged a friends car this weekend to maybe get a better understanding of this data when I need to tune my own chip when I get my car running. Im going to attach a csv file so maybe someone could give me advice at what to look at when viewing BLMs in logged data and how to deal with them. I can see that the long term seems to be rich but not sure exactly what would needed to be changed in the chip to obtain a more neutral condition.
Here
Old Jun 20, 2004 | 05:43 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: Logged scan
[/URL]
Doc's guessing, your running a Vicksberg Vombat, straight 8, with a CCC ecm.
I don't think so
What engine, ecm, mask/code are your using?.
Old Jun 20, 2004 | 06:23 PM
shaggy56's Avatar
Car: 71 Nova
This log came from a 1993 4.3 liter tbi S10 Lb4 truck engine. The ecm is 16168625 which I belive is $E6 program id byte.
Old Jun 21, 2004 | 08:43 PM
shaggy56's Avatar
Car: 71 Nova
Man its tough for 4.3 liter tbi owners. Not even one person viewing the s-10 boards where I posted this question. I should tell my friend to dump his engine.
Old Jun 22, 2004 | 07:57 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
I recommend a nice '90-'92 5.7l TPI engine from either a Firebird or a Camaro. Use the '730 ECM and wiring harness from same. S-10 will really scoot then. . .
RBob.
Old Jun 22, 2004 | 01:31 PM
shaggy56's Avatar
Car: 71 Nova
I tell him that all the time but he says its not worth it so he just keeps it basically stock. Its not all that easy putting a 350 in an S-10 because you need to spend extra on lots of special parts since its such a tight fit. Last night I started making an ecu file for the E6 bin but I was having a hard time getting the checksum info correct. The VE tables are open throttle, closed throttle, and some other Wot parameters and everything goes to 6400 rpm.
1992Z28!
Nov 19, 2015 07:33 AM
L98GTA87
Oct 19, 2015 10:43 PM
RGB2015
Sep 20, 2015 09:26 PM
BWilcox
Sep 20, 2015 12:19 PM
IROCThe5.7L
Sep 17, 2015 07:48 AM
