dyno bins
dyno bins
I went to the dyno with my friend yesterday. Check out the power I made. He has a 89 formula w/ hot cam, siamese runners,stock tb, 11.1 CR, l98 AL heads, auto trans.
The graph is stock vs my tuning. The reason I posted this here is that I have the before and after bin. I would love to share it with the board and discuss what I did to the prom chip/tables.
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'm curious as to whether the torque curve falls off as a result of the LTR setup, or if that's how the HOT cam looks. I haven't seen many dyno graphs with the HOT cam. Since the LT4 HOT cam is what I have, it is something I would like to know! I plan to go with something other than a LTR setup, but I'm not sure what else to use with the fastburns.
I would like to see some of what you've done with the bin, even just a general discussion of, not necessarily the actual bins..... I can see from the AFR graphs that it was running a bit lean, but I'm sure there's more to it than that!
Also, is the smoothness of the curves a result of the tune, or a different sample rate, or something else? I noticed that they look much smoother!
I'm not a hardcore dyno guy. Experience tells me to measure performance in all of the drive gears( 1/4 mile run). The dyno measures power in third gear only. Get the picture? BUT at the same time look at the entire power curve. There is a dramatic difference. THat car will run better at the track.
Actually he is taking it to the track next week. My 3500rpm 10" tq converter will be installed, so I'll also be up there. We are going to line em up. His best with a junk custom chip was 12.9 @ 104(1.8 60ft) ,I think. My best so far this year has been 13.3 @ 104 with a 2.060ft. My formula is set up for cornering so it couldn't hook. It will next week. I should be close to 12.5.
I always take my prom burning equipment and log every run. The formula has ran about 30 times this year at GIR (test and tune). The a/f ratio has been @ 10.0 and I have also tried 13.1 . It likes the fuel curve rich at the tq peak and leaner up top. Right now I shift out at 6000 rpms , or so.. Wot spark is simple. I have ran 32*/34*/36*/38*/39* of s/a. Running with 39* burned the porcelain on my plugs(even though there was only a slight detonation on one cylinder)
Car: 84 Z28
Originally posted by 11sORbust
It's smoother because the tune. The stock settings sucked! If you want to see the bin changes, I can send both bins your way. It was spark and fuel changes for the most part...
I have a holley stealth ram. I think your hot cam would love it. FYI the torque always falls off in the upper rpms(on dyno graphs). Switching from the LTR setup to HSR would only gain you HP and extend your rpm range(if your valvethrain is up to snuff). I should know because I switched from a TPI intake to the HSR. There was no falloff in torque. For a 350, I would just make sure the CR is at or above 11.0 .
I was thinking about the RamJet manifold. The kit is a bit more than I planned on spending, but you get quite a bit.
I'll be interested to see what the track times are....
I'd also be interested in seeing the before and after bins if you don't mind sending them my way. quiktrp@netzero.net.
Those are huge before and after differences, good job
My firewall deleted the attachments, so I didn't get a chance to view them. I think it's because you sent the message with no valid sender and no message body. I tried to nab them off the server as well, but they were deleted as soon as I downloaded the messages to my computer
Car: Depends on what day it is..
Engine: Um, Chevy small-block
Transmission: One that shifts
Axle/Gears: Got those too...
Just one question- is the 89 Formula still running a '165 ecm or has it been converted to SD?
If it is still a '165, e-mail the before and after bins to Br1dgemann@cs.com
Thanks Tim.
Thanks Tim.
Yes, send the bins my way anyway. I am curious to see what changes you specifically made to the timing tables.
Thanks.
Thanks.
Car: Iroc-Z
Engine: 355 AFR'd HSR
Car: 1991 Z28
Engine: 5.7
Transmission: A4
I would like to take a look at them also. I am running the Hot Cam with LTR setup. I was curious if switching over to HSR would help my car. I am running the stock 3.23 gears which I think is hurting me. Thanks, BranZ
qtomlb@hotmail.com
qtomlb@hotmail.com
Car: 1990 Formula
Transmission: WC T5
Try and take the email and push the forward button. Then you should be able to take the attachments from that and use the "save to disk" option. My firewall does the same BS
EDIT: Try this addy: quiktrp@cbcast.com
Craig Moates has a nice little upload section. I'll just upload em there and post the link for everybody. I'm starting to get flooded with request.
These bins cannot be used for your car. It's not matched to your engine and will cause damage. Keep in mind, once I upload the bins I'll be looking for discussion on the table changes.
Car: An Ol Buick
Engine: Vsick
IMO, just post a few of the tables, and let folks work out the details on their own. Once you say *look at this* or this works *for me*, folks often get lazy and don't really try figuring you've done all that can be done.
For some it's just human nature to take things for granted, and or assume things. Just the way things are, and no ones gonna be able to change it.
Just saying it doesn't always work.
Tim-
I will be waiting to see the bins on Moate's website. Thanks again.
Al
I think he was just saying people in general. I know I have ran a milder version of grumpy's timing table when I first started tuning. It was more out of a curiosity thing than lazyness though
It's just human nature though. Humans are a lazy animal, if they can find an easier way out of something, many will take that route instead of learning how to do it themselves.
Just my $.00002
EDIT: I'll be watching for the bins as well. I checked a couple times last night, but moates.net seemed to be down.
Just my $.00002
Anyway, it is not my intention to start a flame war, I just believe it is a good learning tool to actually compare stock vs modified bins and ask intelligent questions about why a particular change was made.
Cheers
moates site is down. I would post it at www.efi-tuning.com
but I have a lifetime ban from there. Maybe somebody else will host it.
Car: American Iron Firebird
Engine: The little 305 that could.
Transmission: Richmond T-10
Axle/Gears: Floater 9" - 3.64 gears
Car: check
Engine: check
Transmission: check
. . . .the millions that emailed me (that I've never seen at diy-prom).....
RBob.
Car: An Ol Buick
Engine: Vsick
That's why I made sure it would cause damage if used.
Sorry, but I don't agree with that under any circumstance. It's one thing to PD an error, but PD something that you'll know cause damage, shows some degree of intent. Not good.
Car: An Ol Buick
Engine: Vsick
Originally posted by Br1dgeman
But we are not the general population.
The world is full of folks that see lawyers as being an answer, to any guestion.
Geesh, booby trapping, info. that you public domain?.
But I will modify some stuff to prevent startup. Is that ok, Boss?
Car: 84 Z28
http://www.moates.net/files/2)%20Cus...yno%20crap.zip
Guys, I think grumpy is trying to help. Even though it's hard to tell sometimes
Tell me what you think . I have everything packed in there(dyno sheet, bins and datamaster log).
Car: 84 Z28
Car: 1990 Formula
Transmission: WC T5
Ok, I had the link up for long enough. What did you guys think of the bins?(sitting here waiting for discussion
) i am assuming that because of the hot cam it must idle pretty high, that is why the lower cells are 0'ed out. That is the reason, correct?
I also noticed that you left values in ve at the high map values 80 up why?
Second,
I see all knock retard has been eliminated.
Third,
You disabled your EGR.
Do you think that by doing #2 and 3 that it helped smooth out the power curve?
Lastly
You increased the AE, was this for better throttle response?
Car: 1990 Formula
Transmission: WC T5
No, I did that to disable the bin. I don't know any other way to do that. 80% up is the wot area so I left it...
What happens in this circumstance?
What do it run off(or refer to) of in this situatuion?
Car: 1990 Formula
Transmission: WC T5
Weak stock tables
Weak stock tables
I see lots of knock counts with spark retard
We are both typing at the same time...
makes it bit tought.. I'll wait a minute. Last edited by novass; Jun 26, 2004 at 09:01 AM.
Car: 1990 Formula
Transmission: WC T5
I mean I made it so other people can't just slap it in their car. It was talked about in this post...
Second,
Third,
Lastly
Comparing the before and after timing tables, it appears you increased timing in the 95 and 100 kpa range in the 4000 rpm areas. How did you determine the engine wanted it in only two pulls and how did you dicides on how much to add?
More questions?
darwinprice
17
Oct 11, 2015 11:51 PM
LT1Formula
Oct 8, 2015 08:34 PM
