idle problem
Old Jun 20, 2004 | 01:31 PM
level's Avatar
Car: 1987 transam
Engine: 383 /w superram
Transmission: 700r4 /w 2800rpm stall
idle problem
ok so i startup tunerpro go to log idle blm's wait for the car to enter closed loop.. see that my idle blms are 150? LEAN! so i go to maf table 1 and increase fuel... go back out to the car and see the blms dropped.. so i take it around the block.. now its lean again? and it keeps doing this until you can smell gas standing behind the car..
theres no way its lean? o2 sensor voltage stays around 195/240mv at idle
Old Jun 20, 2004 | 02:21 PM
vernw's Avatar
Car: 91 Formula WS6 (Black, T-Tops)
Engine: 383 MiniRam (529 HP, 519 TQ - DD2K)
Transmission: Built '97 T56, Pro 5.0, CF-DF
Axle/Gears: 4.11 posi Ford 9"
Try a new O2 sensor. If you're in closed loop it should be rapidly cycling from .2 - .8 or so over and over. Sounds like your has gone south.....
- Vern
Old Jun 20, 2004 | 05:09 PM
jeepguy553's Avatar
Car: 1980 Jeep CJ7
Engine: AMC 360 with GM TBI
Transmission: TF727 set for kill...let's get it on!!!
My new one (O2) may be doing the same thing. I have a cal BIN that worked really well 2 weeks ago. I fired the Jeep up today and my BLMs at idle were sitting around 116 with INTs of 120-125.
Bizarre...
Old Jun 20, 2004 | 06:11 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: idle problem
Sounds like a poisioned O2 sensor, or a Bosch one.
Try another sensor. If you can just grab a handful for cheap at a junkyard, they'll do just fine. Just don't get a Bosch, they have the world's worst track record.
Personally, I consider it worth while to use heated ones.
Old Jun 20, 2004 | 11:42 PM
vernw's Avatar
Have you disconnected the battery so that it has to relearn since then? Other wise it makes no sense if you haven't changed anything. Have you done anything to it at all?
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
perZ
Aug 15, 2015 01:17 PM
