9th injector and ARAP bin
Old Jul 6, 2004 | 11:27 AM
jgifford's Avatar
Car: 1986 Z28
Engine: 355TPI 380hp
Transmission: Rebuilt 700r w/ Transgo Shift Kit
I'm in the process of doing a ARAP bin for my 86 355 TPI. Anyway, I've done a search and found that certain things needed to be changed to use this bin on pre-89 MAF systems. But I'm concerned about the 9th injector. I know you can just unplug it, but I just hate to change the way she starts right now. Correct me if I'm wrong, but doesn't the 9th injector run seperate from the ECM? For arguementative (?SP) purposes, could you set all crank pw multipliers vs. Ref. Pulse to 0 and let the cold start injector do what it is supposed to? Also, is the cold start injector entirely seperate from the ECM?
Old Jul 6, 2004 | 11:53 AM
Cobra289's Avatar
Car: Cobra Kit Car
Engine: 350 HSR
Transmission: TKO 600
Axle/Gears: 3.31
The mask $6E don’t have the cold start injector.
So if you decided to change to the ARAP you need normally to disconnect the 9th injector.
But as you say you can live the injector in position because it is not controlled by the ECM, just a Temp sensor.
I have a very good experience with out the CSI by just control the “crank pw multipliers vs. Ref. Pulse”
This will solve the problem that some times you get with a $6E (hard to start)
In case that you decide to remove the CSI here are my settings.
My car will start writhing 1.2 sec. see my data logging:
http://www.donostia.demon.nl/csv.zip
My “crank pw multipliers vs. Ref. Pulse” is:
Code:
Crank Fuel PW Multiplier vs. Ref. Pulse
Ref. Pulse   Multiplier
     24     0.20
     23     0.20
     22     0.20
     21     0.20
     20     0.20
     19     0.20
     18     0.20
     17     0.20
     16     0.25
     15     0.25
     14     0.25
     13     0.25
     12     0.25
     11     0.25
     10     0.50
      9     0.50
      8     0.25
      7     0.25
      6     0.25
      5     0.25
      4     1.00
      3     0.25
      2     0.30
      1     0.30
Regards,
Cobra289
Old Jul 6, 2004 | 11:55 AM
eric305TPI's Avatar
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
The cold start uses a switch that supplies the 9th injector power while in the crank position under a certain coolant temp. The system doesn't tie into the ECM system at all. Unplug the injector and/or the switch and cover/protect the exposed plugs. You may or may not have to adjust the cranking PW's and multipliers vs. reference pulses to get it to start the way you want it to.
Old Jul 6, 2004 | 12:10 PM
Cobra289's Avatar
Car: Cobra Kit Car
Engine: 350 HSR
Axle/Gears: 3.31
I forgot to mention that I think you need also zero the “Crank Fuel PW vs. Coolant Temp”
My “Crank Fuel PW vs. Coolant Temp” is:
Code:
  Deg F   PW (msec)
    241    18.75
    219    18.75
    198    17.19
    176    17.19
    154    15.63
    133    14.06
    111    14.06
     90    14.06
     68    15.63
     46    25.00
     25    35.16
      3    75.00
    -18   139.85
    -40   160.17
There is also a
“Crank Fuel PW vs. TPS”
  % TPS   Multiplier
    100     0.00
   87.5     0.00
   75.0     1.00
   62.5     1.00
   50.0     1.00
   37.5     1.00
   25.0     1.00
   12.5     1.00
      0     1.00
Regards,
Cobra289
92-Formula
Dec 12, 2015 10:34 PM
ronchic
Mid-Atlantic Region
Sep 15, 2015 08:04 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
