AFR's for speed
Old Jul 12, 2004 | 04:40 PM
Captain C's Avatar
Car: 1985 IROC-Z
Engine: 1989 350 4 bolt roller block
Transmission: ProBuilt 700R4 Road Race with Edge 9.5" 2800 stall lockup converter
AFR's for speed
It seems like in my old carb days that you wanted to run around a 13.2 AFR for power and around 15.5 for mileage. It also seems like there was a crossover point for torque vs horsepower. Something on the order of run a little lean for extra torque until the Horsepower/Torque crossover point and then go rich.
Is there any validity to this point?????
Also, if it is true it adds other questions. Like, if you can only set up the ECM for one AFR setting instead of by rpm range, can you fool the ECM by changing VE tables so that the mixture will read rich when you datalog it?
I'm new to this stuff but I'm reading a lot and will only have more questions to ask as I go along
Old Jul 12, 2004 | 04:52 PM
JoBy's Avatar
Car: 1984 Corvette
Engine: Turbo 350
Transmission: 4L80E with TCI T-Com
With an ECM you can set the AFR value you want for each RPM and load point.
Old Jul 12, 2004 | 07:51 PM
Grumpy's Avatar
Car: An Ol Buick
Engine: Vsick
Re: AFR's for speed
There's often some validity somewhere along the line in a universal statement. Best answer, is some what and sometimes.
Just set the ecm to run open loop, and you can run any AFR you want anywhere.
Old Jul 13, 2004 | 10:05 AM
Captain C's Avatar
Car: 1985 IROC-Z
Thanks for the info!!!!
83 Crossfire TA
Sep 18, 2015 12:01 PM
355tpipickup
Sep 13, 2015 11:35 PM
adelane
Sep 9, 2015 08:51 PM
Eric-86sc
Sep 7, 2015 02:10 PM
FLAP
Camaros Wanted
Sep 2, 2015 09:22 AM
