Part Throttle intermit rich, now what?
Car: 1990 Corvette, 1985 C-10 1979 Subun
Engine: 350, 406 HSR
Transmission: manual, 200 4r
I have a 727 ecm 1990, I have changed ignition curve on the the chip and installed an adjustable fp regulator and pressure is set at 53 psi with no vac. Here is the problem: After car is warmed up when I cruise at part throttle 1400 rpm for the 50 sec the ecm looks for to set a fault I get the check engine light and code 45 is set.
I have recorded data using datamaster and at the point the o2 sensor flat lines for a long time here is what I have for data: o2 volts around 850, blm/int 128, spark adv 34.5.
What needs to be done to correct the fault? I have never messed with the VE values but looking at the data it appears to be O.K. I have replaced the o2 sensor, opened the air cleaner lid, and bypassed the throttle body water.
Anyone else have this problem? Any suggestions? What else do I need to look at? This problem seems to consistently happen at the same place on the road everyday as I drive back and forth to work so I believe I can rule out electrical problem.
Any help is greatly appreciated! This forum is great for new chip burners like myself.
Car: 82 ElCamino, looking for a 3rd gen
Engine: 305 TPI(427SB in progress) 730 $8D
Transmission: THM350 (Getting a 4L80E soon)
Axle/Gears: 10 Bolt w/ 2.43 gears :(
If you could post the log in the datamaster format and in a CSV format we might be able to look at it and see what is going on.
Well I can't get the file to go, looks like the file type is not accepted by this forum?
I noticed you are building a 406, I have one done with the vortec heads and am trying to decide what FI system to use. Any suggestions?
