attempting first aldl cable
Old Jul 27, 2004 | 02:55 PM
1990GTA's Avatar
Car: 1990 GTA
Engine: 5.7 T.P.I.
Axle/Gears: 3:23
I just went to Radio Shack and got the stuff to make it. When I asked for the 10k Ohm resistors, they had 1/2 watt and 1/4 watt. Which one should I use?, I bought the 1/2 watt.
Also , what is a good gauge wire to use?
Old Jul 27, 2004 | 03:43 PM
AlexJH's Avatar
Engine: 5.7L V8
1/4 watt would have been fine, but 1/2 will work also.
I use whatever wire is on my desk at the time. The current draw for the MAX232 or 2 transistor circuits are small, I'd say that anything 20 or bigger (smaller numerically) would be fine.
Old Jul 27, 2004 | 03:44 PM
Dave_Jones's Avatar
Car: 83 TA, 89 TTA, others
Engine: ZZ4 TPI, LC2 turbo v6
Transmission: several, mostly broken
Doesn't matter with the resistor, either the 1/4 or 1/2 watt version will be fine. The wire gauge isn't that critical either. I'd probably use something around 20-22 AWG. Larger is just excess bulk, and smaller might be a bit fragile for an item that might get tossed around in the car a lot.
Bubbajones_ya
Oct 25, 2015 08:01 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
TMZIrocZ350
Oct 7, 2015 12:09 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
rs_z28_vert
Sep 30, 2015 09:47 PM
