First Scan Wanting Some Feed Back
Old Jul 27, 2004 | 06:14 PM
MTPFI-MAF's Avatar
Car: 1982 CAMARO;
Engine: 1985 LB9;
Transmission: T-5/
I just received my V8 ANZA memcal, This will almost finish my 870-165 swap, I took a couple of Scans to see if I could get TunerPro and Moates ECM 852 To link with my home made cable, Which they did Fine. I would like someone to look at these and see if there is anything out of the ordinary. In the scans the car isn't running Because It will be another week before I have a Flash N' Burn, HDR1, GP1 so that I can disable VATS and get some scans of the car running.
Bare with me this is my first scan and just wanting some Input on if any sensors look out of range for The car not running.
Here is the link to the .CSV Files
http://www.f-body383.100megsfree5.com/AAB/CSV-Files.htm
Old Jul 28, 2004 | 12:23 PM
anesthes's Avatar
TGO Supporter/Moderator
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: First Scan Wanting Some Feed Back
You need to adjust your TPS so the log shows 0.0% TPS. Right now the voltage is just a hair low.
When your ready send us logs of it running.
Once it is running, you'll wanna adjust your IAC too before you do any tuning.
-- Joe
Fast355
Dec 2, 2016 06:33 PM
NufNuffZ28
Aug 14, 2015 09:12 AM
bbsr72
Brakes
Aug 12, 2015 10:44 AM
armybyrd
Aug 10, 2015 09:23 PM
Kaweh
Aug 9, 2015 02:54 PM
