$6E fuel tuning
Old Aug 26, 2004 | 12:05 PM
Black 91 Z28's Avatar
Car: 1991 Camaro Z28
$6E fuel tuning
I've searched through the posts on this subject and have seen several different methods. The most predominate one seems to be altering the injector constant and then messing with the MAF tables. I've also read that this can cause trouble down the road.
Is this the correct thing to do or is there another method. I've looked in the $32B and seen the BPW vs RPM vs LV8 table but noticed that it's not in the $6E. So, is the above method the best way to tune?? If you know, please reply as I'll be tuning a friends car tomorow.
Old Aug 26, 2004 | 04:04 PM
clippjr8's Avatar
If you are talking about part throttle cruise only, then the above way is correct. If you are tuning wide open throttle, then you will need to use the pe vs rpm table to richen or lean it up in pe mode. Playing with the maf tables will not cause any problems down the road as long as the tune is correct. Just datalog and change the tables at the locations that are lean or rich. Idle is the most difficult to tune as 128 blm makes the nose burn from the fumes, so pick a point that you can live with, usually a little leaner, and go with it. good luck
Old Aug 27, 2004 | 09:34 AM
Yes, I was just refering to part throttle and idle.
MustangBeater20
Oct 29, 2022 09:20 PM
9192camaro
16
Feb 3, 2019 12:21 AM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
ezobens
Aug 19, 2015 10:29 PM
