BLM'S through the roof
Old Aug 28, 2004 | 11:11 PM
IrocJason's Avatar
Car: 1986 Iroc Camaro
Engine: 5.3 ltr
Axle/Gears: moser 9in, 4.56gear
OK its a newbie question. I have a 165 ecm and tuning the$32b stock bin. I'm using the tunercat software and a romulator. The issue I'm running into is the blm is sky rocketing to 160. Now if I'm correct that means the car is lean and ecm is trying to richen it up (please correct me if I'm wrong). The funky thing is it smells awfully rich. It will make your eyes burn. Also my o2 is showing 0 volts when car is running. Now if I gas it a little the voltage will come up to about .100 volts. I guess what my question is what should the voltage be reading at when obtaining 14.7 afr? I'm thinking I might possible have a bad o2. Another question is what should my tps voltage be set at when car is at idle? I'm tring to make sure everything with my sensors are set properley and functioning well before I even attemp to tune the ecm. I would appretiate some help. Thanks for taking the time to read this.
Old Aug 29, 2004 | 12:03 AM
92GTA's Avatar
Yup, replace that o2. 160 is the max BTW but your rich because the o2 should be giving it ATLEAST .500volts...
TPS should be .54 but up to .57 is ok...
Old Aug 29, 2004 | 01:09 PM
IrocJason's Avatar
Engine: 5.3 ltr
Thanks for the help. I'm going to replace the o2 and also double check for exhaust leaks and hopefully figure this beast out.
Old Aug 29, 2004 | 03:47 PM
onebinky's Avatar
Just an FYI, an o2 will always fail lean, which in turn commands rich.
So like 92GTA said, replace that o2
Mark_ZZ3
May 24, 2018 01:02 PM
antman89iroc
36
Jan 31, 2016 08:42 AM
LC2 TECH
Oct 13, 2015 11:53 PM
FormulaEngland
Sep 30, 2015 01:50 PM
formula00ra
Interior Parts Wanted
Sep 28, 2015 11:50 AM
