help with engine/prom
Old Aug 30, 2004 | 01:29 PM
metalic5's Avatar
Car: 87 GTA
Engine: 5.3 LSx
Axle/Gears: 3.70 Borg Warner 9 bolt
hi guys i have an '87 gta with a 350, i'm running a holley stealth ram, and lt4 hot cam, 10:1 compression, and 041 casting heads, anyways i'm having problem with the car running, it'll run but it doesnt want to idle smooth, it feels lik if it has a miss, and i cant get the timing right, i tried everything, i tried advancing it, retarding it, nothing seems to work, also it kind of boggs off the line. some one please help me, do i need a chip, do i need anything special, some one help me.
oh yea also i think my knock sencor is broken will this also cause the problems i'm having?
Old Aug 30, 2004 | 02:25 PM
jwscab's Avatar
Engine: Many
Transmission: Quite a few
use the search function on the board here, in maybe tpi forum as well, using 'hsr', 'maf', and 'lean pop', I remember someone posting what they did to cure their issues, which sound similar, with a similar combination also, I just don't remember who it was. they may also chime in here too........
Old Aug 30, 2004 | 02:39 PM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
Read the stickies at the top .
Then start on and see where that gets u :-)
This board is for do it yourself prom tuning. Everythign u need to begin is at your fingertips
later
JEremy
