idle MAP readings
Old Aug 30, 2004 | 11:26 PM
Tibo's Avatar
Car: 1991 Z28 Vert
Engine: 383 single plane efi
Axle/Gears: 8.8 with 3.73s
idle MAP readings
I was wanting to know what everyone's map readings are at idle. I am most curious about engines that have a cam with a 112 lobe seperation.
Old Aug 30, 2004 | 11:44 PM
gta324's Avatar
Car: GTA -89
Engine: Blown 415"
Transmission: 4L80E
Axle/Gears: Strange 12-bolt
Its not only lobe sep that affects MAP at idle.......
here are my readings with cc306
https://www.thirdgen.org/techbb2/sho...hreadid=246142
/N.
Old Aug 31, 2004 | 03:05 AM
3.8TransAM's Avatar
Car: 91 GTA, 91 Formula, 89 TTA
Engine: all 225+ RWHP
Transmission: all OD
Axle/Gears: Always the good ones
My stocker is in the 30-35kpa in gear at idle.
My hotcammed 350 was around 60kpa(+-5) at idle in gear.
Both of these assume warmed up and a fairly decent tune.
Idle timing also influences this as well as does whether u are rich/lean at an idle and how smooth u get the idle(error corrections and so forth)
later
Jeremy
Old Aug 31, 2004 | 04:34 AM
conv90's Avatar
Car: superrammed V
Engine: 396 SBC Speed Density
Axle/Gears: Dana44 3.45
later
Jeremy
My Vette TPI (355) with stock cam is in the 33-37 kpa in gear at idle at 675 - 700 rpm.
When I put in P or N (the stock chip adds 100 rpm ) is in the 24-26 kpa in gear at idle at 775- 800rpm.
Is it normal that with increased rpm (800 vs 700) the KPa values decreases?
I was thinking that with higher rpm level the throttle(s) was open a bit more, so I was thinking that low vacuum (Hg of mercury) readings was expected. Low vacuum (Hg of mercury) = Higher Kpa values.
...I add... If I rev the engine in N or P up to reach 1,000 or 1,500 rpm I have Higher Kpa values if the TPS is grater of 0% and loooowwwwer (in the 10 kpa range) if the rpm level is high and TPS is 0%.
Old Aug 31, 2004 | 11:52 AM
Tibo's Avatar
Car: 1991 Z28 Vert
Great, now I don't feel so bad. I usually have a MAP reading of 52-55 at idle with the sig below. So I guess that I am doing alright.
specialized
Jun 18, 2022 09:26 AM
bamaboy0323
Sep 3, 2015 06:07 AM
mdtoren
Aug 23, 2015 12:52 PM
onebadazzsrt
Aug 15, 2015 07:00 AM
