base timing question
Old Sep 3, 2004 | 09:13 PM
onebinky's Avatar
Just a quick question
How come so many guys run a base timing of 8,10, or even 12 degrees even though they burn their own proms? Isn't it easier on the starter to run lower timing? Just curious because I set mine to 0* BTDC, changed my constant to reflect that, and haven't had any noticable issues yet. Would I be better off bumping the base timing to 10* or so?
That might sound like kind of a "newbie" question, but in all the hundreds of hours of researching and hundreds more tuning, I haven't been able to find the answer to this.
Thanks guys
Old Sep 4, 2004 | 01:30 AM
87_TA's Avatar
Well.. I would like to do a test on that some time...
Because I think that lying to the ECM about timing changes your injector timing also....
Not sure what the pros or cons of that are yet...
Bye the way I run my static @ 20.. and it starts really nice like that.
Old Sep 4, 2004 | 01:53 AM
onebinky's Avatar
wow, 20 deg
Do you still have the timing constant set at the factory setting, or have you changed it to the 20 deg value? Are you running the stock GM starter, or a gear reduction/hi torque type?
After I get everything else dialed in, I'll probably toy around with a few different values and see what results I get.
Old Sep 4, 2004 | 07:29 AM
JP84Z430HP's Avatar
Car: 84 Z28
Engine: 355 (fastburn heads, LT4 HOT cam)
Axle/Gears: 9-bolt, 3.27
I'm sure for some, whatever ir was stock is where it still is, as long as it starts fine. Which isn't a bad thing. My thinking is set it where it starts and runs best (through trial and error) since it will vary from engine to engine. It all has to do with compression ratio, cam profile, cam timing, etc.... It is, of course, important for it to start well both cold and hot.
Old Sep 4, 2004 | 11:15 AM
87_TA's Avatar
Originally posted by onebinky
wow, 20 deg
My prom is set to 20 as well.
Old Sep 4, 2004 | 12:42 PM
onebinky's Avatar
Vintageracer
Jan 10, 2020 05:33 PM
ezobens
Aug 19, 2015 10:29 PM
redmaroz
Aug 16, 2015 11:40 PM
Feffman
Mid-West Region
Aug 13, 2015 07:12 AM
Feffman
Aug 13, 2015 07:11 AM
