IAC min/max keep alive learn temps.
Old Sep 9, 2004 | 08:58 PM
MikeT 88IROC350's Avatar
Car: 1988 IROC-Z
Transmission: 700R4 w/TransGo
Axle/Gears: BW 9-bolt w/3.73s
Just what exacly does this parameter do? The temps seem to be set real high in my bin, which I can now read with TunerPro. Like 185f for min and 250f for max temps. I would think I should be lowering the min temp, since I have a modified cooling system, and thus my engine runs much cooler than stock.
What you all think?
Old Sep 9, 2004 | 11:45 PM
92GTA's Avatar
I have my max set to 100.25C (212.45F) and my min set to 59.75C (139.55F)...
My fans are set so my car NEVER goes over 200F and I'm going to install a 180 degree thermostat too...
Old Sep 10, 2004 | 09:43 PM
Car: 1988 IROC-Z
92GTA, so what good does that do, if your car never gets over 200F? If you consider that GM factory setups had 195F T-stats, and very high fan turn-on temps, then this IAC keep alive learn thing might work.
Anyone have a clue as to what GM was doing with this parameter? Is this just another set of enable temps for the IAC to use specific tables?
Old Sep 10, 2004 | 10:24 PM
92GTA's Avatar
Because if my min is 139 and my max is 212, then my max of 200 is close enough to my max so that if my engine does get a little hotter I'm covered and since it runs at a lower temp I lowered the min to 130. Seems like it's the perfect range to me
Old Sep 11, 2004 | 04:11 PM
Car: 1988 IROC-Z
Woops, me bad, I didnt look at your first post close enough, before I replied!
I thought 212F was your min for some reason. Your range is fine. I will have to lower my min temp.
Still don't really know what this parameter does.
Rocket-Doc
Nov 14, 2015 02:08 PM
Spyder_TheGamer
Oct 2, 2015 12:25 PM
thejimsterz28
Sep 30, 2015 08:52 PM
mfp189
Sep 27, 2015 09:25 AM
