TunerPro RT ALDL Datastream editor and WB logging
Old Sep 29, 2004 | 09:38 PM
Mark A 91Formula's Avatar
Car: 91 Formula
Axle/Gears: 10 Bolt 3.23
I Downloaded TunerPro RT and started playing with some of the functions. I must say I am beginning to love this program. The level of freedom is just amazing.
I am currently using the WB patch for the $58 code, courtesy of Dig. Which allows you to input the raw WB output into the datastream. Combine that with the Table lookup feature in TunerPro and viola! Actual AFR readout in my Scans! Now I can datalog with one program again instead of using one for ALDL and one for the WB! Just gotta finetune it a bit now.
Thanks to Mark Mansur and Turbodig :hail:
Old Sep 30, 2004 | 02:58 AM
1320 Right Ln.'s Avatar
aawww shi* son.... haha, that's cool.
Old Sep 30, 2004 | 05:40 AM
novass's Avatar
Car: 1990 Formula
Transmission: WC T5
Re: TunerPro RT ALDL Datastream editor and WB logging
Originally posted by Mark A 91Formula
I I am currently using the WB patch for the $58 code, courtesy of Dig.
Is the WB $58 patch posted somwhere? Would appreaciate the info.
Old Sep 30, 2004 | 09:09 AM
Car: 91 Formula
http://digware.lunarpages.com/digware/index.html
Thats the page. Wire the WB output to pin F14 and the data reads under "Target AFR" in any scanner.
Digs also has a few other patches that translate the raw data directly to AFR so you dont need to use a lookup table, but it's dependant on the WB setup your using.
xodus2002
Jul 17, 2020 09:08 AM
Mark_ZZ3
May 24, 2018 01:02 PM
ULTM8Z
Oct 2, 2015 01:25 PM
BWilcox
Sep 20, 2015 12:19 PM
greenyone
Sep 8, 2015 08:41 PM
